Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
If you have a smart phone, there is an app for finding degrees of slope for it. Most folks go by the pucker factor. If it is uncomfortable in the seat mowing side slope, as in you are sliding out of the seat, then it likely needs to be mowed up and down. Unless it is really steep at the turning point, then you can likely just make a sharp turn at the top and head back down.
If it is really steep, I will straight back up the slope then turn at a slant slightly at the top so that the tractor is almost aligned with the next mowing path and then turn back straight and mow back down.
From your photos, it looks like only one parcel is steep enough to require backing up and that is the upper right area and it may even be too steep to mow even backing up. With R4 tires, you will likely loose traction when backing up if it is too steep to mow. I have mown pond dams that were over 45 degree slope and would loose traction sometimes backing up. You dont have to worry about flipping forward when backing up a hill or going down a hill in a straight line. The bushhog is your counterweight to help avoid this.
NOTE: If you start loosing traction (rear wheels sliding) when travelling up or down a hill, just work it like sliding on ice, steer in the direction of the slide so as to keep your direction of travel going straight down the hill. DO NOT LET THE TRACTOR GET SIDE WAYS AS IT MAY FLIP.
