New tie rods
/ New tie rods #1
tractorcrazy
How tight should the nut be on new tie rod ends .they have castle nuts .thanks
/ New tie rods #2
Tight. Use a standard torque chart for the diameter and thread pitch of your rod end and either grade 5 or 8.8 hardness (depending on whether the dimensions are Imperial or Metric) if you don't have a published spec for the specific parts.
/ New tie rods #3
If they use a taper mount, run the nut down to about 20 ft/lbs. then tighten to first available pin hole--Never back off to find hole. Install the cotter pin.
/ New tie rods #4
20 lb/ft could be woefully inadequate on a larger size rod end. Torque needs to be relative to size and sufficient to seat the taper. Striking the side of the receiving socket with a hammer during the tightening process will help with the seating.
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2007 Chevy Suburban (A62679)
2007 Chevy...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
