New tie rods
/ New tie rods #1
tractorcrazy
How tight should the nut be on new tie rod ends .they have castle nuts .thanks
/ New tie rods #2
Tight. Use a standard torque chart for the diameter and thread pitch of your rod end and either grade 5 or 8.8 hardness (depending on whether the dimensions are Imperial or Metric) if you don't have a published spec for the specific parts.
/ New tie rods #3
If they use a taper mount, run the nut down to about 20 ft/lbs. then tighten to first available pin hole--Never back off to find hole. Install the cotter pin.
/ New tie rods #4
20 lb/ft could be woefully inadequate on a larger size rod end. Torque needs to be relative to size and sufficient to seat the taper. Striking the side of the receiving socket with a hammer during the tightening process will help with the seating.
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 23ft...
2002 Kubota BX1800 Utility Tractor (A63116)
2002 Kubota BX1800...
Red Cedar Glider Chair (A61569)
Red Cedar Glider...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
