New shop started
/ New shop started #463
That is what I need, a small roller. Our lane is about ½ mile, and rolling it a few times a year (especially before the winter snow) would be perfect for setting the gravel in nice and tight! I helped a friend/neighbor expand his driveway a few weeks ago, and the driving back and forth, moving 6" left each time with the tractor to pack it down helped but not nearly as effective as a roller! Your place looks great - keep up the good work!
/ New shop started
Thx
Wife loves the driveway so she is happy w purchase
Win win
/ New shop started #465
Your place look really nice. The older I get, the more I admire a really nice lawn. Thick, lush, green, no weeds, or fire ant mounds. One day I'd really love to have my place look like that!!!
/ New shop started
Funny u say that
I guess I am now the same?
When we bought the place, “as long as it was green” I didn’t care. It was all weeds and I would chuckle at the “manicure” look. (This place is in the woods and I prefer a more wild look)
We then added a quarterly fertilizer/weed treatment company
After 3 yrs of “treatment” my weeds turned into “grass” and I must say, I like the look now also!
I’m getting old
/ New shop started
Rescue the Quadractor day
Threw a belt and now even though I went thorough it last year, looks like another tear down and fix a some shifting issues for the long term
Loosing garage space to “projects”
/ New shop started
Ok so the issue was wear within a sliding rack that turns Fwd/back shifting motion into left/right rack movement.
Rack with the 3 worn guides. Zinc or aluminum?
You can see the wear between rod and guide
So boring on the mill with the D’andrea boring head to insert an oilite bushing
Turning bushing on lathe for press fit
Assembly and prior to cutting off excess on rightmost guide
What a difference, shifts like a car and no more belts jumping out of phase
/ New shop started #471
you have wonderful skills to do that
skills of a machinist are so valuable
could you explain a little more about what that boring head does? other than look seriously impressive
I assume it's a tool holder of some sort
/ New shop started
Boring heads can be a simple as a toolholder to hold a boring bar (cutter.)
The next step up is “adjustable” where you shut off spindle, turn a dial/key/nut to adjust the cutter out or in and re-commence w boring
The next step up, you don’t have to power off the spindle, just leave mill on and hold a ring or dial (like mine on the right side)
The next step up also has a “power feed” option and can be used for facing(most typically) so as the spindle turns the cutter advances outward
Mine does all of those things.
So to bore, get yourself centered, dial out until you start to make contact. Set your zero, dial out cut (this one can dial out 0.0005) then use quill or power feed on mill to bore, come back out of hole and dial out a bit more on head and bore again. No need to shut down etc
/ New shop started
I am also much more of a hack than a machinist!
/ New shop started
Also got a dead simplicity 2010 (tho I think it has a 16 in it)
no spark, I let it sit all summer. Jump pack to get the hydro lift to pick up the weed cutter and a helping hand by the “younger” machine into the shop
now it will get some attention.
/ New shop started
Well, that time of year I guess.
As expected, bad “coil “ but I didn’t expect so much of a nest.
5 dead mice
Popped out motor, cleaned, converted to electronic (yes I reversed the new coil as it was a points flywheel) and popped back in. Good for another year!
/ New shop started
Thank u!
I’m blessed
I let friends share in the usage
Today was fluid film of winter vehicles and trailers
/ New shop started #478
BTW, in high school and a bit of college, I worked at a motorcycle shop that also worked on small engines. Mice nest are a big reason for motors getting burned up.
/ New shop started #479
Well it is time to build the toy/tool barn.
This is my humble shop site
Scott's Shop
So the barn is 50x60. The rear metal shop is about 25x30. Above that metal shop will be the wood shop. The rest of the space will go floor to rafters, all open (for automotive work etc). Rear right corner behind beam is welding and fab. Upper woodshed will have stair and a garage door for access to use forklift to lift larger projects and tools up there. We will have 3phase and 110/220.
Here goes...
Moving trees
Site
Excavation
Foundation in, 200 truckloads of fill
Rear, covered apron site for blacksmithing and storage
The 84 big red checking it out, front doors are 18'x10' each
John Deere 6125R (A60462)
John Deere 6125R...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
213097 (A64276)
213097 (A64276)
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2022 Bobcat E42 (A64126)
2022 Bobcat E42...
