Rear Finish Mower New purchase advice
/ New purchase advice #1
tedwards
Massey 1240
I mow about 10 acres of what was a horse pasture so it is a little uneven, with 20 years of hoof prints. I have a MF 1240 tractor, about 25-30 hp and was using a Deere 272. It's time to upgrade! I believe I'm between a Woods PRD7200 and a Land Pride FDR2572. Any info or guidence or other recomendations would be appreciated!
/ New purchase advice #2
Welcome to TBN. Both brands are good and i think you would be happy with which ever one you choose. :thumbsup:
/ New purchase advice #3
I use an FDR2584 (7') behind my similar tractor. It easily cuts down pasture stuff including a lot of russian olive and wild berry bushes. You can set the deck from ground scarf to 8" grass height for getting whatever field height you want. I added the Gator mulching type blades to avoid clumping and accelerate the decomposition.
This is a rear discharge mower that can be run at max tractor ground speed. Nice job on the lawn, too. I think most people would agree that the wider the mower, the better from a time, fuel standpoint. Once the initial cutting is done, the rest is maintenance from that point on in time.
Do you need anything other than the mulching blades for a good mulching job?
/ New purchase advice #5
Both are really good mowers, we use a Caroni RFM which has worked really well for us. They work best when cutting short grass, so we mostly use rotary cutters. For a good finish cut the RFM does a good job as does a good flail mower.
/ New purchase advice #6
Both the Woods and Landpride finish mowers are very good. But if it was my money, I'd buy the Landpride.
/ New purchase advice #7
Both are good mowers. I picked the Woods PRD7200 over Land Pride because I like the spring tensioned anti-scalp castors on the Woods. The PRD7200 is my second Woods RFM. I have also owned a Woods 72" RM660 and a Caroni 72" RFM. I like the quality of the cut on Woods mowers.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2018 CATERPILLAR 249D SKID STEER (A62129)
2018 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
2025 JMR 4x8 Forklift Safety Basket (A61567)
2025 JMR 4x8...
