new PHD first and second use ...
/ new PHD first and second use ... #1
davebar
kubota b1550
The first 21 holes with the 6 inch auger on my b1550 went really easy with only about 3 holes that I couldn't get down to 2ft. the next 40 holes I couldn't get any down to 2 feet! Working in the rain a few holes I'd only get a coupla inches down before it would stop and just spin without biting. hitting the bottom of the hole with the pry bar loosened up the clay easily and turned up no rocks just hard clay or hard pan. Are there different auger bits for different type soils?? Would it help if I notched the bits to make a serated edge?? Any other ideas to get the auger more bite?? hang a weight off the arm?? Does bouncing the phd in the hole (like a pile drvr) damage the gearhead?
thanks,
dave
/ new PHD first and second use ... #2
You can get downpressure kits for a lot of PHDs. I don't know how much they are but I don't think they are too bad.
/ new PHD first and second use ... #3
I had looked into buying a PHD about 6 months back. I was told that the biggest thing is to get a good bit. Bits are made for different types of soil. You may not have the right type of bit for the soil you are digging in.
/ new PHD first and second use ... #4
The best augers I've seen have replaceable cutting edges. They just bolt on to the leading edge. They're usually offset so one bites the inner diameter of the hole bottom and the other bites the outside diameter of the hole bottom. You can make your own out of some hardened steel (Local steel shop) and devise a way to bolt them on.
I made a set and just used 1/2" mild steel and "hard faced" them with the same welding rods used for "hard facing" backhoe buckets and blades. They don't need to be too sharp. They seemed to work alright, but eventually got broken by heavy rocks. I think the factory cutting edges might be carbide or similar.
/ new PHD first and second use ... #5
Check for grass on the cutting edge. I have had that foul up the digging. bcs
/ new PHD first and second use ... #6
Also try moving forward or backward while the auger is down and rotating. bcs
/ new PHD first and second use ... #7
davebar i rented one and after about 15 holes i filed down the edge of the cutting blade seem to work better
good luck edt
thanks for all the suggestions. I'll give 'em a try this wkend when I'm on the farm next.
dave
/ new PHD first and second use ... #9
Dave, my light weight JD 4100 (about 2500 lbs equiped) is too light to scratch my hard pan. My PHD is a Bush Hog 2100 with down pressure, adding another 150 lbs of down pressure. When my clay is soft from rain or irrigation, it easily drills a 12-inch bit 4 feet down, no down pressure needed. /forums/images/graemlins/cool.gif But if my ground is dry, it's hard as rock and down pressure is worthless. Hard pan is worse--no amount of rain or watering helps. The PHD barely scratches hard pan no matter what time of year. So most of my drilling is planned for springtime. If I could do it again, I'd forget the downpressure. Expensive & no return I can see. I've also tried a 3000+ lb Bobcat on the hard pan and it was useless too, and just scratched it. So, IMO, hard pan takes a really heavy machine, or you do it the hard way--with a digging pole. /forums/images/graemlins/frown.gif Best of luck. -Jonathan
/ new PHD first and second use ... #10
I bought a Bush Hog SPHD with Downpressure and it is outstanding! $1500 was very steep but it will go through anything I give it, very pleased.
/ new PHD first and second use ... #11
Keith, your tractor sounds nice. At 2900 lbs your 4410 is almost two of mine. With attachments your weight goes weigh up. /forums/images/graemlins/smile.gif My 4100 is roughly 1500 lbs stripped. With a loader & auger, mine approaches 2300, and up to 2700 with a heavy mower. I don't think your HP helps but it sure doesn't hurt. The final difference is the ground. Mine is clay with rocks throughout. When dry its like concrete and the auger spins uselessly. When wet, I don't even connect the down pressure as it isn't needed. But there must be a point when even hard pan gives way. So what's your soil like? - Jonathan
/ new PHD first and second use ... #12
My soil is mush now since all we have had this year in Western New York is rain - Argh! Under normal conditions it is heavy clay, no chance I was going to pass the perk test - $5,000 later for the snad filter. I heard nothing but bad things about PHD from friends and neighbors and was very hesitant but the bush hog with the down pressure has made a believer out of me.
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A65643)
2014 JAYCO...
42" Hydraulic Smooth Lip Swivel Bucket (A62679)
42" Hydraulic...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
213091 (A64276)
213091 (A64276)
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
