JerryG
Super Member
I have one inch black iron pipe to run 1.2 million BTUs. I don't remember the pressure.
who are you replying to with this?
I'm old school, I prefer black iron for gas lines. 1" is larger than you need but it won't hurt anything except your wallet. One thing that is very important in using black pipe is to only use malleable fittings, not black cast iron fittings. Cast iron fittings will break if distorted, and if there is a fire and something moves the malleable will move (to a point) but bci shatters. I was told it is not a good idea to have an open gas pipe dumping gas into a building that is on firesrossman said:I was thinking that I would run 1" black pipe the length of the house and then put in T's at all the places that I might need gas. I know that the water heater has a 3/4" input.
So is 1" too big, too small or just right for the main run through the house?
Scot
LBrown59 said:I don't recall ever seeing that big of a gas line in any house.
Most I have seen are either 1/2 or 3/8.
LBrown59 said:I've never paid some one to run gas or water lines.
Always did it my self.
Scot
You can use the Yellow Plastic Gas Line out doors but it's not permitted inside.AndyM said:At the time, I lived on a city lot and felt it was best to pay someone to do a project like that.
ruglad03835 said:It has been around for a while and it is the latest and greatest.
Inspector507, thanks for that info. I didn't know about that. Most of the "improvements" in materials in the plumbing and heating trade improve the ease or speed of installation, not necessarily the quality of the product. I still like black iron pipe for gas, but I like a lot of the old ways (showing my ageInspector507 said:I thought the same way until I heard about the Class Action lawsuit settlement with 4 manufacturers of CSST. You can read about it here
If your area is prone to lightning storms, like ours is, you might want to take the precautions that the manufacturers are recommending.
SPIKER said:I was under the impression that the flexible piping mentioned above was for final hook up only and could not exceed 3' in length? anyhow I haven't seen any of the new NFPA86 standards in over a few years...
anyhow good luck.
mark m
Inspector507 said:Mark,
What you're used to seeing is a flexible gas connector. It's used to make a flexible final connection to your appliance. CSST is flexible corrugated stainless steel tubing used to pipe the whole house. It's sold by many brand names such as, Omegaflex, Wardflex, Trac-Pipe, Gastite....etc. It does have it's draw backs though.
