New Kubota Corrosion
   / New Kubota Corrosion #52
"they'd be taking it back." Such a dumb comment.
Oh yeah? You think that doesn't happen? Is it odd to you that a company should deliver on the promise of quality in the products they sell?
Just because you're willing to settle for subpar quality at inflated prices doesn't mean anyone else ought to.
   / New Kubota Corrosion #53
Lol. “Tell me you don’t work on cars without telling me you don’t work on cars.”
Brake rotors just take humidity to rust. I think it has to do with them being cast. Every rotor I’ve ever met was rusty unless the pad had scrubbed it off recently.
Plus the fact that a friction surface is likely to rust because the surface iron and totally bare.
   / New Kubota Corrosion #54
". I live in southern New Hampshire, not by the beach."
How close to the 'beach' would be the question. A few years back, I read an article regarding ocean salt air & corrosion. It might apply here??
My father-in-law lives right on the ocean, and his roughly 15 year Deere 4520 doesn't have corrosion remotely as bad as this year-old Kubota. This is subpar quality control, and it's ridiculous to see anyone acting like this is normal.
   / New Kubota Corrosion #55
Hello All, I have been reading a learning a ton on this site. Thank you to all who contribute.
I have a 1 year old Kubota 4760, 2022 model delivered in May of 2023. I am appauled by the corrosion on all the silver plated hardware. The tractor has 55 hours on it, and is kept either in my garage or under a 3-sided barn, it does not see the rain/snow. It stays on my property and gets washed a few times a year. I live in southern New Hampshire, not by the beach. It appears that just condensation has corroded every single plated fitting/hardware item. I have a BH92 on this as well, and all the silver connectors, even hose clamps, are corroded. Am I just expecting too much?
Some of the fittings say China right on them. I'm dissapointed and will now go and try to steelwool/oil all the parts, but what a waste of time. Here are pictures of the hydro connections for the FEL, under the cab and for 3rd funtion valve. I took these pictures a few weeks ago, on a warm morning. You can see some droplets from the humid air on the cold metal. Notice on the middle picture on the cab, some connections have zero corrosion, but most have the oxidation. I really expected more for the money spent on this. Any thoughts or insite? Thanks!
Those steel Fittings are likely coated with aluminum not zinc.
Moisture of course is the enemy. Try throwing a tarp over it to help prevent condensation forming. Spray affected parts with WD40.
   / New Kubota Corrosion #56
I sold a +30 Year old Kubota B7200 10 years ago, for what I paid for it. The Yellow zinc hardware and fittings were in excellent condition and the faded paint was still totally adhered with no rust. Steel parts were sandblasted and had white primer under the topcoat. That along and the solid welding, rugged electrical connections, quality plastics, along general attention to detail has made Kubota and Toyota top tier brands. I hope they are not following Boeing's fall from quality.
PS: the RTVX is $35K now. Our country is in need of some drastic changes.
   / New Kubota Corrosion #57
I never saw how tractors ship from Japan, but always assumed they'd be in containers. That would seem to give protection from salt spray wouldn't it?
   / New Kubota Corrosion #58
A very bad idea. Have you ever seen a classic car that a person threw a tarp over it to "preserve" it, only to find the interior filled with mold?
If one wants to prevent condensation from forming, one needs air movement. A ceiling fan set on low does wonders and costs pennies to run.
   / New Kubota Corrosion #59
Like most here, my 2008 Kubota does not have any corrosion like that, it does get washed with hose maybe at most once a year....but here is maybe a wild thought, I notice when I wash my dark vehicles with house water from hose, I get salt like water spots.....I attribute those to the water softner salt we use with our rural house. Could water softener salt and ocean air be a contributer to the OP's corrosion on his fitting etc ?
   / New Kubota Corrosion #60
Does your shelter have a dirt floor? My car had corrosion after I stored it in my dirt floor barn for the winter. These photos you've shared look way worse than what I've dealt with, but the car was inside for only 5 months in the winter When no dew came up from the ground like it does every night in the summer, along with the high humidity we see near lake Ontario. Viewing these pictures of corrosion on your machine looks like chemical reaction or poor metal used in manufacturing those parts. The only thing I can can recommend is to spray the underside of the tractor (or at the least, the effected parts) with oil. We do that every fall here in the rust belt to keep the salt from eating our vehicles up. Some people use vegetable oil, some use used motor oil (not recommended) or there are effective products in spray cans available just for this purpose at a lot of automotive stores. Fluid Film is a popular one, Rust Check is another. They're designed to penetrate the metal whether it's healthy with no corrosion or if it's corroded so the rust or corrosion can't take hold. I don't know what material your fittings are made of. But some metals probably won't absorb oil and corrode mostly on the surfaces. Aluminum acts that way. I'm curious to see what you find out from the manufacturer about those parts. Good luck!
UNUSED LANDHONOR LHR-WS22 WEBBING SLINGS (A54757)
UNUSED LANDHONOR...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
