And it goes on like water...You could try Penetrol. It is like a thin varnish that will give some protection yet not interfere with threads or gum things up like paint. Home Depot has it. It is good for a lot of other things too.
Really, are you real ?? Now you're blaming the owner, a tractor is supposed to be made to stay outside, where do you use a tractor? Outside not inside of a heating garage. Where do dealers keep their tractors until they're sold??Try parking indoors in a heated garage
Look at the condensation on your painted steel...this is an owner issue, not a K issue
Seems to me it’s a problem with the materials used by the company that makes fittings for Kubota (Jis, from what I understand) and ultimately the responsibility of Kubota to make good on it. I would hope that Kubota would stand behind their product.Hello All, I have been reading a learning a ton on this site. Thank you to all who contribute.
I have a 1 year old Kubota 4760, 2022 model delivered in May of 2023. I am appauled by the corrosion on all the silver plated hardware. The tractor has 55 hours on it, and is kept either in my garage or under a 3-sided barn, it does not see the rain/snow. It stays on my property and gets washed a few times a year. I live in southern New Hampshire, not by the beach. It appears that just condensation has corroded every single plated fitting/hardware item. I have a BH92 on this as well, and all the silver connectors, even hose clamps, are corroded. Am I just expecting too much?
Some of the fittings say China right on them. I'm dissapointed and will now go and try to steelwool/oil all the parts, but what a waste of time. Here are pictures of the hydro connections for the FEL, under the cab and for 3rd funtion valve. I took these pictures a few weeks ago, on a warm morning. You can see some droplets from the humid air on the cold metal. Notice on the middle picture on the cab, some connections have zero corrosion, but most have the oxidation. I really expected more for the money spent on this. Any thoughts or insite? Thanks!
"they'd be taking it back." Such a dumb comment.I don't know what environment you've run it in, or how you store it, but I can say if I got a new Kubota and it did that, with the price increases they have done over the last two years.....they'd be taking it back.
Plus the fact that a friction surface is likely to rust because the surface iron and totally bare.Lol. “Tell me you don’t work on cars without telling me you don’t work on cars.”
Brake rotors just take humidity to rust. I think it has to do with them being cast. Every rotor I’ve ever met was rusty unless the pad had scrubbed it off recently.
". I live in southern New Hampshire, not by the beach."
How close to the 'beach' would be the question. A few years back, I read an article regarding ocean salt air & corrosion. It might apply here??
Those steel Fittings are likely coated with aluminum not zinc.Hello All, I have been reading a learning a ton on this site. Thank you to all who contribute.
A very bad idea. Have you ever seen a classic car that a person threw a tarp over it to "preserve" it, only to find the interior filled with mold?Try throwing a tarp over it to help prevent condensation forming.
Does your shelter have a dirt floor? My car had corrosion after I stored it in my dirt floor barn for the winter. These photos you've shared look way worse than what I've dealt with, but the car was inside for only 5 months in the winter When no dew came up from the ground like it does every night in the summer, along with the high humidity we see near lake Ontario. Viewing these pictures of corrosion on your machine looks like chemical reaction or poor metal used in manufacturing those parts. The only thing I can can recommend is to spray the underside of the tractor (or at the least, the effected parts) with oil. We do that every fall here in the rust belt to keep the salt from eating our vehicles up. Some people use vegetable oil, some use used motor oil (not recommended) or there are effective products in spray cans available just for this purpose at a lot of automotive stores. Fluid Film is a popular one, Rust Check is another. They're designed to penetrate the metal whether it's healthy with no corrosion or if it's corroded so the rust or corrosion can't take hold. I don't know what material your fittings are made of. But some metals probably won't absorb oil and corrode mostly on the surfaces. Aluminum acts that way. I'm curious to see what you find out from the manufacturer about those parts. Good luck!Hello All, I have been reading a learning a ton on this site. Thank you to all who contribute.
