New John Deere Owner
/ New John Deere Owner #1
Ron JD670
Jacksonville in S. Oregon
for Cristmas 2011 found used Joh Deere 670 w/ 40 hrs and options
Hello
My brother convinced me I needed a tractor for my 4.5 acre rock pile. My back when I moved the fire wood in for Christmas confirmed the matter.
I found a JD670 with 40 hours that had been covered and or barned most of it's life with FEL, PH auger, and rake. They delivered just before christmas and I have been creating a mess since then getting used to the tools. Almost took out the gate I was trying to improve the clearance on. Found out that the football size rocks are as much a problem for the PH auger as for me by hand.
Had to make a contraption to hang the auger on before I could get it off the 3 pt as I sure did not want to take it appart again. Had fun making a contraption to Hang a 200# roll of fencing wire from the FEL . Treated it like a paper towel roller with some chain and a piece of pipe. I rolled out 150 feet without a pinched finger or stained back. Now I know why I needed a tractor.
I look foward to finding some good ideas here. Will share some pictures when I figure out how.
Best wishes
/ New John Deere Owner #4
Welcome to TBN!!!
A 670 with 40 hours!!!!! 40 hours??
My first tractor was a 670. Great little machine!!
They put out about 20 Engine HP and 17 PTO HP which will be a good fit for your 4.5 acres (it was for my 2.5 acres).
I ran a 60" rear finishing mower (a BEFCO that was sold with the tractor) and 60" Land Pride rotary cutter. The mower did fine...the cutter bogged the tractor down a bit, now and then.
BTW, the 670 begat the 790 and current 3005...so there's still a lot of 670 heritage.
/ New John Deere Owner #5
Welcome to TBN.:thumbsup:
/ New John Deere Owner #7
A John Deere 670 with 40 hours is a rare find - will be watching for the pictures. A couple of years ago I bought a 4wd Kubota B8200 with 42 hours. It was like stepping through a time warp - old and new at the same time. Welcome to TBN!
psdx
Thank you for the warm welcome. Yea I did not want to pay buy new and the few used units I found were realy used hard. The prior owner of the 670 was a machinist and he and his son both bought 670s. The son had 400 hours and the dad had 40. I could not pass it up. Now everyone thinks I am an Oregon Ducks fan.
I have atached pix of the tractor and the stand for haniging the post hole digger. Note still working on modification for a tripod to make the 3PT easier to hook up on the auger.
/ New John Deere Owner #10
Congrats on the 670 and :welcome: to TBN! One of my friends has a 670 with over 2000 hours and it's still running strong. :thumbsup:
/ New John Deere Owner #11
psdx
Thank you for the warm welcome. Yea I did not want to pay buy new and the few used units I found were realy used hard. The prior owner was a machinist and he and his son both bought 670s. The son had 400 hours and the dad had 40. I could not pass it up. Now everyone thinks I am an Oregon Ducks fan.
Very cool .. Was the post hole auger stand built using a saw horse kit? If so ... clever !
Hosspuller
Thank you for the COOL:cool:
You are correct. I had the saw horse kit sitting around from a prior project and I had 4 inch X 1/4 bolts on hand so I drilled through both sides of the saw horse clamp and the 2X6 header, added some large washers and and nylock nuts to make sure the clamp could not release. I did not want to depend only on wood screws, when my neck was on the line. I trimmed the header bottom so the legs would spread at the bottom and used some old chain to hang from the header with a simple hook on the other side. I then added some old garden hose over the chain to avoid damaging the old paint and rust on the auger. My only regret was not making the header a bit longer as it is hard to get in to take the auger bit off and on.
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
New Quick Attach Hay Spear (A65579)
New Quick Attach...
2022 EZ-GO ELITE...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
