New headlights
/ New headlights #1
Scotty Dive
Ct
Yanmar 2020D
This isn't pretty but I came across a set of led lights for little money and they fit in the area where the sealed beams are with no modifications. I tried to find a led lights that were roughly 4 x 6 but no luck.
Of course they are brighter than the stock lights and use less amps by 50%.
The top of the light wedges in to the top of the sheet metal opening and the bottom of the light mounts in the original stock mounting hole. I was considering making a shroud to go around the light but it's not worth the effort to me. I needed lighting up front and this should do the trick.
Look at this on eBay 2pcs 4inch 18W CREE LED Work Light Bar 4WD Offroad Spot Fog ATV SUV Driving Lamp | eBay
/ New headlights #2
Like driving around at high noon now! :thumbsup:
/ New headlights #5
I wonder if the OE lens can still be used to make it look original.
/ New headlights #6
i was thinking something similar. Maybe take a grinder and cut it off and somehow epoxy it into place or something?
/ New headlights #7
That is possible. Or find a tractor bone yard with the same lenses to hack and form.
JOHN DEERE 1210A GRAIN CART (A64277)
JOHN DEERE 1210A...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
1042 (A60430)
1042 (A60430)
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
2023 Gulf Stream Trailer (A62613)
2023 Gulf Stream...
