New headlights
/ New headlights #1
Scotty Dive
Ct
Yanmar 2020D
This isn't pretty but I came across a set of led lights for little money and they fit in the area where the sealed beams are with no modifications. I tried to find a led lights that were roughly 4 x 6 but no luck.
Of course they are brighter than the stock lights and use less amps by 50%.
The top of the light wedges in to the top of the sheet metal opening and the bottom of the light mounts in the original stock mounting hole. I was considering making a shroud to go around the light but it's not worth the effort to me. I needed lighting up front and this should do the trick.
Look at this on eBay 2pcs 4inch 18W CREE LED Work Light Bar 4WD Offroad Spot Fog ATV SUV Driving Lamp | eBay
/ New headlights #2
Like driving around at high noon now! :thumbsup:
/ New headlights #5
I wonder if the OE lens can still be used to make it look original.
/ New headlights #6
i was thinking something similar. Maybe take a grinder and cut it off and somehow epoxy it into place or something?
/ New headlights #7
That is possible. Or find a tractor bone yard with the same lenses to hack and form.
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
Steel Coils (A65640)
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
