New garage time!
/ New garage time! #1,601
What do you use for bait? The previous owner of my property left a large live trap and I've got some coons living under my deck I want to get rid of. I don't know that they're causing any damage but eventually my dog is going to dig under there to get to them. At my last place I had to take up some deck boards to rescue my moronic stuck dog.
Sardines in a live trap.
/ New garage time!
I'm here to give plumbers an aneurysm.
It's been a while since I have done this, by my 6th solder I had the right amount of heat and solder, top right.
/ New garage time!
I added the return to the furnace. Not the prettiest, but it's in there and no leaks. I have a shutoff valve after the boiler, then the T junction, then the shutoff valve from the hot water tank. I'm working my way backwards.
Work had to stop as my wife wants to bathe my kid and apparently hot water is required for that. No navy showers I guess.
After this I'll have to drain hte system again, then cut in the supply line. Then run copper to the ceiling and over to the tank.
/ New garage time! #1,610
How close are you to being done with all your current or planned projects? ;)
/ New garage time!
I need to install the new mini split heat pump yet, and wife's new washer and dryer. Then I'm going to enclose the front garage to make a wine room and knock out the old wash room to make a full bathroom out of hte first floor powder room. Then i'll be installing a new 2 car garage addition with a new master bedroom over top. I'll need to reconfigure the second floor hallway to make access.
Lady that wanted 2 dozen eggs texted me, she had 12 pumpkins for me. So I fired up the cart and met her at the driveway. Chickens will be eating good today!
/ New garage time! #1,614
You are a hoot!
/ New garage time!
Problem. My Hot water return crosses over the removable air filter. So either I find a longer flexible hose or I need to replumb it. The lines on there are 24" and I'm not seeing a FIP to FIP 36" on HD's website. So it looks like I need to cut the line and route it back so the hose can go behind the filter.
/ New garage time! #1,617
Why not use two flex lines and connect them with a nipple?
/ New garage time! #1,619
I want to do it right and have it look nice. I am not a fan of flex lines to begin with, i feel like they're a point of failure.
Home Depot sells a stainless steel braided line that looks very adequate for the job. It sure simplified my last hot water tank install.
Edited to change the word "makes" to "sells".
/ New garage time!
Well that's done. I drained the water out of hte line, cut it, but every time i went to heat it up, more water came out. Had to resolder a few times. Now I can take the filter out.
New electric run. 25' of 10/2 is $100. I was 6" short to make it, so I had to put a junction box. I considered movign the tank 6" closer. I misplaced the screws for the electrical cover, and the ground screw is part of the electrical cover, so I can't run it without it being screwed d0own.
2017 Peterbilt 320 New Way 20ASL 20yd Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
TOYOTA 5K FORK LIFT (A67714)
TOYOTA 5K FORK...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
1981 LINK BELT HSP 8028 (A67714)
1981 LINK BELT HSP...
