New garage time!
/ New garage time! #541
A guy at work has that Milwaukee 12 volt driver and it works really well. not as much torque as what you can get out of a big 18 or 20 volt one, but it works very well for putting in smaller fasteners.
Aaron Z
/ New garage time! #542
Why don’t you hose them down before handling them? A little moisture that’ll evaporate pretty quick wouldn’t hurt anything would it? And starting at 6 would help.
/ New garage time!
I've never worked with metal in building anything like this, so this is very interesting for me. I remember you saying that you have an inspector and you are under Code for your area, so that tells me that this is acceptable framing for what you are using. It just surprises me that those self tapping screws are load bearing. I'm used to joist hangers and approved fasteners for each hole in the joist hanger.
This is really getting exciting!!!
I just looked it up, for 12ga #10-16 has a shear strength of 1215lbs, #10-18 has a shear strength of 1645lbs. With 9 of them in the track and 18 in the beam, I think it'll be ok. That area won't get much use anyway.
/ New garage time!
That's a good idea. Starting at 6 would be ideal, but unfortunately my real job has other plans, and i'm at the mercy of my friend. We normally go until 6 but today was just abusive.
/ New garage time! #546
Likewise, and I also was looking to build a detached shop with 24ft span and did not want supports. If I resurrect my build, I will definitely look into this method for flooring. Also surprised about the self tapping screws! Following along even closer now. Please give as much detail as to how this ties into the sills and flooring.
/ New garage time! #550
These are wood floor trusses...
/ New garage time! #551
I had those type of wood trusses on my first house.
/ New garage time! #552
Curious as to the height of the wood joists vs. metal each spanning 24ft?
I bought direct from the factory. I was going to use a taller one, but they showed me a shorter one with a thicker web, that cost less and had same performance.
/ New garage time! #553
Might be cheaper but I doubt the same performance all things considered. I-shaped cross section is the most efficient way to design simple engineered beam where bending strength is driving factor vs. shear strength (web strength). The web does relatively little to help with bending strength. Trusses are another level of strength, where instead of relying on the web for stability and shear loads, the truss members are instead compression/tension members but they generally take more vertical space to be efficient... a la roof trusses.
Sometimes space is a restriction requiring stronger materials or more efficient space for bending strengths... especially for long spans. Nowadays it is cheaper to manufacture a wood engineered I beam than a the raw material cost of say a 2x12 fir and can handle longer spans and are more stable.
Sorry for what might appear as a lecture here but I am guessing many don't understand why all the choices in joists.
/ New garage time!
Locally those are known as tri-force joists. We looked at 3, LVL's, i-joists, and tri-force joists. LVL's were $250 each, 12" on center and can't drill. i-joists had issues with the span and were about $130 each and couldn't get wet, tri-force the guy at the supply yard recommended against them saying alot of people complain of sagging after a period of time.
The tradeready joists were $4024.83 for 33x 24' which was $121.96 each, $376.90 for the 5 at 14'10" which is $75.38, 9 pieces of rim track 12' 12ga for $515.31 or $57.26 each.
With the steel joists it feels like I'm getting the strongest product for the lowest cost. The rim track is extra though.
/ New garage time! #555
Those joist with OSB for the upright part and the little piece of pine for the web ( i joist ) suck IMO. There’s the yellow laminated beam that’s good stuff but it’s expensive.
/ New garage time! #556
Amazing price differences.
/ New garage time! #557
Are you going to have to use the self tapping screws from h*** for the sub floor?
/ New garage time!
I'm not sure what I'm doing for subfloor yet. The hex heads aren't going to work, I need a different self tapping screw which I don't have yet. I need to do bridging first though I think. Well, maybe not, if bridging pulls them out of 16" it would screw up my grid. It might be a good idea to put the plywood down first so I have everything in the correct position before I cut bridging.
/ New garage time! #559
One would think the steel hoists would stay true while adding the subfloor. With wood or laminate joists, bridging would be first before the subfloor. Just a guess though....
/ New garage time! #560
1987 Kenworth T800 Day Cab (A62613)
1987 Kenworth T800...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
