New fuel can comments.
/ New fuel can comments. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Could they possibly be making something more unsafe trying to make it safer? I got this fuel can a few weeks ago for chainsaw gas. Of course it dispenses fuel pretty slow which actually works ok for filling a chainsaw. There is mechanism you have manipulate that takes two hands to engage but I can live with it. What I couldn’t live with was the green ring in the picture which is a safety thing for holding the spout on. There are teeth on it that won’t let the spout spin off. There is a tiny thumb lever that is suppose disengage the teeth so you can take the spout off to fill the can, yeah right. I cut it off.
/ New fuel can comments. #2
Link doesn't work for me, but if it is like a recent purchase, I bought a new "old style" filler neck and a vent. The way it came is a big PIA, slow, and yes, I spilled a little, unlike the old style.
/ New fuel can comments. #3
When they first started with the safety cans I bit the bullet and bought (6) 5 gallon Jerry cans with regular flexible metal spouts. The 6 cans get my walk behind mower, snow blowers, and small generators through one year.
For 2 cycle engines I use (and like) the "No Spill" brand of fuel containers. Push button to dispense, and they have a clear strip down the side to see the fuel level.
/ New fuel can comments. #5
/ New fuel can comments. #6
Many don’t have a choice due to local or state prohibitions…
I’m glad my existing should be a lifetime supply.
/ New fuel can comments. #7
I never used to think that a gas can could ever become a prized possession. These new fuel cans probably cause more gas to be spilled into the environment than the old ones ever did because they are so functionally messed up.
/ New fuel can comments. #8
Every one of those flexible metal Jerry can spouts that I have used leaks.
/ New fuel can comments. #9
/ New fuel can comments. #10
Guess I'm lucky. Mine have never leaked over the 25 years I've been using them.
/ New fuel can comments. #11
First thing I did on mine was remove that useless, waste of plastic lock. Second was turf the solid spout and put a flexible one on it. Third was drill a hole in the back/top and stick in a tire valve with the Schrader valve removed and put just a valve cap on it. Only problem is you can't buy the corrugated spouts around here any more and I'm dubious of the ones on Scamazon.
/ New fuel can comments. #14
Lots of Youtubes on how to defeat the "safety " features. A big one to fix for me was removing the fine mesh plastic cup in the fill port.
/ New fuel can comments. #15
/ New fuel can comments. #16
For plastic gas cans it’s hard to beat the No Spill cans.
For metal cans, the Justrite Type II are great (watch nozzle size).
If your Jerry cans are leaking, get new cap and nozzle gaskets.
/ New fuel can comments. #17
The ones I had (and threw away) were leaking from the flexible metal tubes, not at the gaskets.
/ New fuel can comments. #18
All my fuel cans (1-5 gal) are old school BLITZ cans. They work great, and no spills. No longer manufactured, but can be found at auctions and garage sales.
/ New fuel can comments. #19
