New Cub Owner
/ New Cub Owner #1
Skyhawkpilot
South West Michigan
Well after 40 years of service my Allis Chalmers B-110 finally gave up. It broke a drive axle tube and the rest of the tractor is tired enough that I decided to retire it and buy something new. I'll restore it later.
After much shopping and research on the web, much of it on this forum and looking at JD, Kabota, Branson, NH, Cub Cadet, and a few others, I decided on a left over new 2007 Cub Cadet 5254 at a local dealer. It has the front weight hanger, cruise control, turf tires and a 60" MMM. I got it for $8500.00 out the door. I have 12 hrs on it now and only time will tell if it was the right choice. I would not want anything bigger to mow the lawn.
I have seen serveral posts about the MMM taking 20 to 40 min to take off or put on, I took 6 min to remove and 8 min to install. I suspect some people may be having to many adult beverages between pin removals :). I will conceed the rear mount mower would be easier but the MMM is better for my needs. I may opt for the kit to lock the deck up so I don't have to remove it for some other simpler chores. I made a trailer hitch for the 3 point. It is nice to back up to many things and just lift and pull.
Thanks to all that posted and helped me make my choice.
/ New Cub Owner #2
Congratulations!
Is that the diesel version or the water cooled Kawasaki?
I bought a 5252 at an auction three years ago, It's about the nicest mowing machine you can imagine in both the cut and comfort.
Curt
/ New Cub Owner
The 5254 is the water cooled Kawasaki with 4 wheel drive. It does have a nice cut but my Allis B-110 had a very nice cut so the Cub has a high standard to live up to. My only complaint is that if you strattle a hump with the deck wheels on either side it tends to scalp some. I'm thinking about adding an anti scalp roller like my Allis has.
/ New Cub Owner #4
Congratulations. I hope you'll be happy with it. I used to have a 5252 as well (I'm too lazy to change my screen name) and thought it mowed very well. It definitely mowed better than the 62D mower deck on the JD 2520 I had subsequent.
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
MANIFOLD (A68842)
MANIFOLD (A68842)
2018 International WorkStar 7500 T/A Dump Truck (A66736)
2018 International...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
