New Chisel Plow
/ New Chisel Plow #1
lakngulf
Lake Martin Alabama
Kioti CK30
I just traded my ATV Bush Hog for a five blade Chisel Plow with springs. I plan to use the chisel to break up some pasture land for wildlife planting. Last year I successfully used the diggers on a box blade, but had problems with the grass clogging. Should not have so much of that problem with the chisel.
What helpful hints do I need to know before putting this plow to work? The land is fairly sandy but is covered with bermuda grass and fescue.
BTW, the dealer from whom I got the plow is a small operation very close to my house in rural central Alabama. He mainly has new three point equiment, trailers, and every now and then has a used tractor on his lot. When I told him I had a Kioti CK30, he said "Those are good tractors. As a matter of fact, they have been talking with him about becoming a dealer" I suggested he go for it, but found that interesting given the dealers Kioti had pulled the plug on recently. Perhaps location is the key.
/ New Chisel Plow #2
Just wonder if your tractor is big enough to pull a 5 blade. Everywhere I look I see 10-15 HP per blade.
/ New Chisel Plow
Although the pasture is heavy in grazing material, the underlying soil is sandy loam. It pulled the box blade with diggers all the way down. I know the chisel blades will be deeper, and will remove a blade if I have to.
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
Used 20' Container (A62679)
Used 20' Container...
John Deere L100A Riding Mower (A65579)
John Deere L100A...
