New Chisel Plow
/ New Chisel Plow #1
lakngulf
Lake Martin Alabama
Kioti CK30
I just traded my ATV Bush Hog for a five blade Chisel Plow with springs. I plan to use the chisel to break up some pasture land for wildlife planting. Last year I successfully used the diggers on a box blade, but had problems with the grass clogging. Should not have so much of that problem with the chisel.
What helpful hints do I need to know before putting this plow to work? The land is fairly sandy but is covered with bermuda grass and fescue.
BTW, the dealer from whom I got the plow is a small operation very close to my house in rural central Alabama. He mainly has new three point equiment, trailers, and every now and then has a used tractor on his lot. When I told him I had a Kioti CK30, he said "Those are good tractors. As a matter of fact, they have been talking with him about becoming a dealer" I suggested he go for it, but found that interesting given the dealers Kioti had pulled the plug on recently. Perhaps location is the key.
/ New Chisel Plow #2
Just wonder if your tractor is big enough to pull a 5 blade. Everywhere I look I see 10-15 HP per blade.
/ New Chisel Plow
Although the pasture is heavy in grazing material, the underlying soil is sandy loam. It pulled the box blade with diggers all the way down. I know the chisel blades will be deeper, and will remove a blade if I have to.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Ritchie Bestway Pull-Type Sprayer (A66285)
Ritchie Bestway...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
