Buying Advice New Backhoe for old tractor
/ New Backhoe for old tractor #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I have a 03' 3510 and have a quote from a dealer for a Mahindra 509 Backhoe with sub-frame for $7900 less tax and freight, They will install unit for $200.
Lots of research on BH's and none offer a subframe for the 3510. prices are not to far from what I was quoted although there are cheaper units available. I really want a sub-frame vs 3 PT hookup. Does this sound like a fair price for the BH?
Any recommendations from Mahindra owners with aftermarket BH?
REALLY!!
No one on this forum has a comment or recomendation on a purchase of $8K worth of equipment!!! :confused:
Looked at Woods BH70X delivered to a local tractor repair shop for $7600.
The Mahindra is a 509 model
HELP ME DECIDE!!!!! :confused2:
kneedeep
/ New Backhoe for old tractor #3
Not a Mahindra owner, but the 3-pt I purchase from IowaFarmEquipment was less. Might call them about a subframe.
If I may ask- What unit do you have and would you recomend the 3PT hookup ??
I am curious as to any one having trouble with that vs the subframe.
:newhere:
/ New Backhoe for old tractor #5
The 509 is one **** of a backhoe and if your dealer is selling it to you for $7900.00 and if it includes the bucket and he had to pay much of any shipping on it, he is lucky to break even. It is a good buy!
Thanks for responding,
I am paying tax and shipping on it. It comes with subframe and bucket and hose kit. Dealer will hook up for $200.
since you are a dealer, 2 questions-
1 Is the 509 a good fit for the 3510?
2 Does Mahindra offer financing on equipment only?
The dealer is 100 miles from me and I have only talked with e-mails to date.
I am almost ready to pull the trigger:D
:thumbsup:
/ New Backhoe for old tractor #7
I bought the 3-pt so I could use is on my dad's JD or my LS. Intent is to make a subframe for the LS, but it is easier just to leave it on the JD. My dad does not use it much anymore. Lots of horror stories on 3-pt breaking tractors in half. I do not intend to do any hard or abusive work with it.
/ New Backhoe for old tractor #8
I'm with Galen. That's a good buy and a great fit. Mahindra will finance equipment over $2500. You better pull the trigger soon the power may go bad.
Dave
/ New Backhoe for old tractor #9
:thumbsup:
I have a friend with a 509 on back of his 4110. He tells me the hydraulic pump gpm is not enough to run a 509 at 100 percent of the 509's capability. If you do get it..........go with a PTO hyd. pump. So with that said......I have no idea if your 3510 and a 509 would be a good fit or match.
Mahindra dealers do offer Agricredit financing, but not sure if they will on used equipment.
FYI.......I have a 511 on my 6520 and it's hyd. pump is almost too small at 11.2 gpm. I have to run at full rpm to get good results. Also, stay away from 3PH mounts for a backhoe, unless you want to see the 3PH mounting lugs break off of your tractor.
hugs, Brandi
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
NEW HOLLAND TS110 TRACTOR (A64280)
NEW HOLLAND TS110...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2018 Ram 1500 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 Crew...
RoGator and Terragator Manuals (A63117)
RoGator and...
