New 2020 Kiotis
   / New 2020 Kiotis #11
H/M/L transmission would put the icing on the cake for me, but I don’t think they have any plans on that right now.
   / New 2020 Kiotis #12
And maybe 1200-1500 lbs of loader lift! I know, I'm dreaming. I just really want a small CUT that can still lift a lot (and handle the heavy rear ballast to do it safely, of course).
Check out the LS MT225e. The loader has 1600# lift at the pins, 2700 # breakout force. 3 point lift is 1800#. Not bad specs for a small CUT. It also has a 3 range transmission.
   / New 2020 Kiotis #13
Or...just buy a CK2610
   / New 2020 Kiotis #18
Whoa, hadn't looked into this cx2510 hst yet. pretty small cut, but the KL2510 loader still lifts almost 1100lbs to 88" off the ground. Anyone know is the bucket is quick-tach? it's gotta be, right? Also, which size mid-mount mowers will be availible?
Given the price disparity of CKs to Kubota Bs/Ls, I don't see how this 2510 wont come in at least a couple grand cheaper. And 84 month 0% financing now too....
   / New 2020 Kiotis #19
Yes, SSQA on the bucket. 60 inch MMM available. Factory 3rd function option. I called in to my local dealer a couple days ago and said he put in his order for CX series on Monday. Said he should have them in a week or two.
And on that loader lift stat, Kioti historically has set their loader lift numbers lower than reality. Take a look at the pump flow numbers. 11.4 G/min is by far more than any other tractor in it's class.
   / New 2020 Kiotis #20
“ 11.4 G/min is by far more than any other tractor in it's class. “ except for LS... 12.6 gal/min. For the MT225E.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
