New 2020 Kiotis
/ New 2020 Kiotis #21
Odd that the gear version lists a 2 range tranny, but the HST shows 3. I wonder which is correct?
/ New 2020 Kiotis #22
11.4 G/min is by far more than any other tractor in it's class. except for LS... 12.6 gal/min. For the MT225E.
Yes but that tractor is not comparable to the CX2510. The more comparably sized LS is the XJ2025 which has the same wheelbase and tires as the CX2510 but the XJ has 8.5 GPM, has 2 speed case and weighs 400 pounds less.
/ New 2020 Kiotis #23
Ah, yes, I was thinking the CK2610H. Both of the KIOTI s are great machines.
/ New 2020 Kiotis #24
Yep, as much as I REALLY want this to be a 3-range HST, until I see one in the flesh, I'm assuming it's 2-range. On one part of the website it's listed as 3, but on the online spec sheet its "No. of Travel Speeds" is listed as "Infinite: 2R". The engine displacement also seems goofy. It's listed as 87 CI and 1647CC. One of those numbers is wrong.
I asked my local dealer for a quote a few days ago and have gotten crickets. They've had very little actual info on this model since it was announced, but that may be more of a reflection of my local dealer than anything else.
/ New 2020 Kiotis #25
I have a quote out as well, dealer ordered some in figures will be 3-4 weeks, will confirm back what i find out as well
/ New 2020 Kiotis #26
So you guys are quoting total hydraulic flow. Is all of that truly available for the loader? On Kioti's KL2510 specs, they list "Rated Flow (Tractor system) :7.66 gpm (29 L/min)", which is obviously a lot lower than 11.3gpm.
/ New 2020 Kiotis #27
11.3 GPM is the total flow including the steering and HST. The spec on the loader is just what it needs for full capability.
/ New 2020 Kiotis #28
It's the same 3A165LW engine that's in several Kiotis. It's a 1.6 liter/100ci engine. Tier 3 engine just FYI. Where's the spec sheet you're seeing 2 range on it?
/ New 2020 Kiotis #29
Kioti's website, on the "Specifications" tab. The displacement discrepancy is listed there as well.
CX251 HST | Kioti Tractors
/ New 2020 Kiotis #30
For speeds it shows "2R" but on the HST info tab it clearly says 3-range. The ranges are contained in the transmission, right? So it could make sense if the gear trans was 2 range, but the HST was 3. We need clarity on this, Kioti!
/ New 2020 Kiotis #31
Yea I would really like to know as well. I sold my ck2510 a few weeks ago in hopes of getting a larger model, but if the CX is truly a 3 range I will strongly reconsider get one with all the changes made.
/ New 2020 Kiotis #32
Dealer near me said he was at the show when the had the cx2510. He said it only had the 2 speed. So he feels the website is wrong.
/ New 2020 Kiotis #33
That's.... a bummer. High range (likely) wont have the power to bulldoze, and low range will be painfully slow for loader work. Pass.
/ New 2020 Kiotis #34
Maybe there was some feedback from the dealers that a 3 range in that model would be beneficial, and we all will pleasantly surprised
/ New 2020 Kiotis #35
So I just saw on a Kioti group page on Facebook, one dealer just received 2 of the new CX2510 today, and he said it has a 3 range hst.
/ New 2020 Kiotis #36
Sorry, my last post was not correct. It is actually still the 2 range.
/ New 2020 Kiotis #37
Well hot ****...
I'm checking up with my dealer again today for pricing. Never would have thought it could be so hard to give someone my money.
/ New 2020 Kiotis #39
Kioti updated the CX2510 page to reflect the 2-Range HST, so that's that.
I pinged Kioti on FB and asked about MSRP. They responded with $14,752 USD for the tractor only, fwiw.
/ New 2020 Kiotis #40
**** it, i love this tractor, but want a 3 range :( back to Kubota B series or Massey 1526
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
2016 POLARIS RANGER 900 UTV (A64047)
2016 POLARIS...
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A59910)
2008 FORD E- 350...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2001 TRAVIS 102" X 37' DUMP TRAILER (A63290)
2001 TRAVIS 102" X...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
