New 2020 Kiotis
   / New 2020 Kiotis #21
Odd that the gear version lists a 2 range tranny, but the HST shows 3. I wonder which is correct?
   / New 2020 Kiotis #22
11.4 G/min is by far more than any other tractor in it's class. except for LS... 12.6 gal/min. For the MT225E.
Yes but that tractor is not comparable to the CX2510. The more comparably sized LS is the XJ2025 which has the same wheelbase and tires as the CX2510 but the XJ has 8.5 GPM, has 2 speed case and weighs 400 pounds less.
   / New 2020 Kiotis #23
Ah, yes, I was thinking the CK2610H. Both of the KIOTI s are great machines.
   / New 2020 Kiotis #24
Yep, as much as I REALLY want this to be a 3-range HST, until I see one in the flesh, I'm assuming it's 2-range. On one part of the website it's listed as 3, but on the online spec sheet its "No. of Travel Speeds" is listed as "Infinite: 2R". The engine displacement also seems goofy. It's listed as 87 CI and 1647CC. One of those numbers is wrong.
I asked my local dealer for a quote a few days ago and have gotten crickets. They've had very little actual info on this model since it was announced, but that may be more of a reflection of my local dealer than anything else.
   / New 2020 Kiotis #25
I have a quote out as well, dealer ordered some in figures will be 3-4 weeks, will confirm back what i find out as well
   / New 2020 Kiotis #26
So you guys are quoting total hydraulic flow. Is all of that truly available for the loader? On Kioti's KL2510 specs, they list "Rated Flow (Tractor system) :7.66 gpm (29 L/min)", which is obviously a lot lower than 11.3gpm.
   / New 2020 Kiotis #27
11.3 GPM is the total flow including the steering and HST. The spec on the loader is just what it needs for full capability.
   / New 2020 Kiotis #28
It's the same 3A165LW engine that's in several Kiotis. It's a 1.6 liter/100ci engine. Tier 3 engine just FYI. Where's the spec sheet you're seeing 2 range on it?
   / New 2020 Kiotis #29
Kioti's website, on the "Specifications" tab. The displacement discrepancy is listed there as well.
CX251 HST | Kioti Tractors
   / New 2020 Kiotis #30
For speeds it shows "2R" but on the HST info tab it clearly says 3-range. The ranges are contained in the transmission, right? So it could make sense if the gear trans was 2 range, but the HST was 3. We need clarity on this, Kioti!
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A55853)
2018 Regal 29OBX...
2017 Ford Taurus Sedan (A55853)
2017 Ford Taurus...
2007 Sterling L9500 (A55973)
2007 Sterling...
Black Steel Diamond Plate (A55758)
Black Steel...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
John Deere 3025E (A53317)
John Deere 3025E...
