Tractor Sizing Need your Kubota widths...
/ Need your Kubota widths... #1
Haymaker101
Western mass
Mahindra, international 1086
Hey everyone,
I'm looking for a narrow tractor to use to mow between my Christmas tree rows and to use for spraying. I plant my trees 6' on center. Although kubota makes the 2320 narrow, roughly 38", there are very few used models. A new model would be around 12k. The older 7500 narrow are hard to find. So I'm asking for suggestions or measurements of your kubotas with ag tires. I'd really like to find a set up close to 40" width. Thanks in advance! Anyone have a narrow model out there?
/ Need your Kubota widths... #2
FWIW...Without doing any measuring tonight...with my B1700 (same as 2100, 2400) a 48" tiller covers my (wide industrial) rear tire tracks...I have the rims turned out for max width (reversing them narrows the track width by 6"-8")...also I think I could slide the rear axles in another 2" on either side...so just an off the wall estimate with this series would give you about a 40" width depending on the tires etc...etc.
/ Need your Kubota widths... #3
Hey everyone,
My 2620 has R4's and is 49". I think the B Series spec sheet lists actual widths.
/ Need your Kubota widths... #5
Try tractordata.com look under Kubota than B series.
/ Need your Kubota widths... #6
You might try a search of vinyard tractors for other models in that category.
Thanks everyone for your replies. I'll keep looking for the narrow model.
Timpte 720 All Aluminum 7000 Tilt Trailer (A63118)
Timpte 720 All...
2020 CATERPILLAR 306CR EXCAVATOR (A62129)
2020 CATERPILLAR...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
