Buying Advice need tractor advice
/ need tractor advice #1
tommorley
argyle,texas
john deere
Have 3 acres to mow. Tired of using Deere Rider. Have to make extra pass when grass is tall. Looking at a 1951 IH Farmall M with 8' brush hog(overkill). In good shape for 3 K. Should I go this route?
/ need tractor advice #2
That's an awfully old tractor. I think that cost something like $2500 brand spankin new in 1954. That says something about our dollar doesn't it? I suppose if it doesn't work out you could always sell it to a collector.
From the data a Super M is a 4 cyl gas engine with gear drive. TractorData.com Farmall Super M tractor information
/ need tractor advice #3
A few things:
Number one-Is it a tricycle or wide front? Run away from a tricycle unless your ground is dead level.
Number two-That's a big Tractor. Do you have obstacles to go around and tight turns to make?
Number three-That's a heavy(ish) tractor. How soft is your soil? Do you mind making ruts?
Number four-a bush hog is not a finish mower. It'll knock it down, but it won't be pretty. Do you need/want pretty?
Number five-that's a tall tractor. Do you have hills? How many? How steep? Anything tall would be pretty sketchy on a steep side hill.
I had two Deere riders and hated them. I found a well used eXmark for about 2500 that's served me well. I mow about 3 acres, mostly a hillside. I've never regretted the zero turn, even though I still need an actual tractor for ground engaging work.
/ need tractor advice #4
I had two Deere riders and hated them. I mow about 3 acres, mostly hillside.
I found a well used Zero-Turn eXmark for about $2,500 that's served me well. I've never regretted the zero turn, even though I still need an actual tractor for ground engaging work.
Second the recommendation of purchasing a dedicated zero-turn mower.
/ need tractor advice #6
It's a trike. Thanks for advice.
That was actually made for row cropping and stuff so is not ideally suited for what you want to do. If you just want to mow then you have the option of machines designed to just mow grass like a zero turn mower. Lots of companies are making those for something in the $2K-$3K price range or more of course. You might even look into a used one if you're into used stuff to save some money. Likely a lot newer than that tractor is for less money too.
/ need tractor advice #7
Not telling you 'how to suck eggs' but how are the blades on your current mower?
There are after-market blades available that do a significantly better job that the original type OEM blades. I changed my D110's blades to a "Predator" and the difference in cut was night & day!
There are probably more after-market blades available too. The "Predator" was what my local Mower Shop had - I couldn't be more pleased.
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
UNUSED RAYTREE REDM32 - 32" HYD EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
Decorative Mermaid Light Post (A61569)
Decorative Mermaid...
