Need Tractor Advice (and education)
/ Need Tractor Advice (and education) #21
I'll throw out my opinion on a couple of issues.
4 wheel drive is a must, make it a must have item, unless you find something used in 2 wheel drive that is a great buy.
What size? Its easy to buy to large or to small. I'm most familiar with the Kubota line so I'll refer to them, but other brands make similar size tractors.
Kubota BX, more for lawn mowing with some tractor abilities. You could get by with a BX, but I think its to small. This would feel more like a very large riding mower.
Kubota B. This is the line I think you should get. Big enough for more serious work, but small enough you could still finish mow with it easily. Keep in mind that Kubota has a large difference in the B line, some are smaller and some are bigger, both in size and horsepower. A B sized Kubota will feel quite a bit bigger than a riding mower, but not feel huge.
Kubota L. Like the B line, they make a lot of different sizes, but this is getting into a more serious tractor. It will move dirt, clear trees, brush hog much better than the smaller Kubotas. As far as finish mowing the yard, I think the L it too big, unless you have a wide open, very large yard. If you did finish mow with a L, you could get a pretty good sized mower for it, maybe approaching 10' wide. If you decided to have a larger yard, this would make mowing quicker.
A couple of options. Buy bigger up front, and when you get done with the heavy work, sell and buy something smaller.
Buy big and get a separate lawn mower.
Buy what you think will work best in the long run, and rent something or pay someone for the heavy work in the beginning.
Something that hasn't been discussed in money. What is your budget? I can tell you if you got a larger L series tractor, with a back hoe, and all the attachments you want, it would be easy to spend 50k in a hurry. You could get into a BX with a lot of attachments for probably 20k. Budget may be the biggest factor in your decision.
Good luck.
Thanks again for all of the information and advice. I had wondered if I'm taking on a bit too much by looking at the different attachments rather than just focusing on a few of the attachments...then again, I wanted to get it all as a "package" rather than having to trickle in the attachments (it is more palatable to my wife that way).
Is there a significant difference between the 3130's and the other ~30HP tractors that Kubota makes (or the same thing with the JD's or others...are there significant differences between the various 30HP models from the same manufacturer?) I just don't know why there are multiple tractors of the same/similar strength unless there are other features. Someone suggested "bells and whistles" but I don't know what qualifies as core functionality vs. bell/whistle.
I appreciate the information, and any additional that people want to give.
-Scott
Budget was asked, and I'm trying to budget somewhere around $20K for the initial setup (that would be for the tractor, FEL, and BrushHog). Additional would be used for getting the other attachments, but $20K is kind of where I've drawn my line.
Of course, anything less than $20K would be exceptional.
-Scott
/ Need Tractor Advice (and education) #24
I agree completely with whoever said not to go overboard on attachments as it is easy to do. I have a rotary tiller that rarely gets used. I bought it because some family members who had never raised a garden thought it would be great and "fun" to grow their own food. Anyone want to guess how many still think that?:laughing:
/ Need Tractor Advice (and education) #25
-Scott
Ok the Grand L series is now out of the running, that leaves the Standard L's some of the B series. A lot of the John Deeres are now out of the running also. (at least as priced around here). Still in the running are Kioti (the other orange tractor), and probably bobcat. too. You should look hard at Kioti if you have a nearby dealer that looks like you can trust, (not some fly by nite with a trailer for a main building) you get a few more things for your hard earned dollar with Kioti.. I have a standard L series Kubota, an L3400HST with the La463 loader. and I paid under your $20,000 and would have had enough left over to get the brush hog, ( I allready had one ) Another new brand on the scene is LS if you have a dealer near you, worth a look. In my area, John Deere's are priced higher than Kubota's, I like the stability of the Kubota dealer network, but I would not be opposed to looking around if I was buying now. Kioti (and bobcat) are the same root manufacture (daedong in Korea) and Kioti has been here now for over 10 years. So they are probably here to stay and getting bigger. keep asking questions, and keep learning.
James K0UA
/ Need Tractor Advice (and education) #26
-Scott
Yeah, that budget would put the green tractors out of the running around here. You need to look at Kubota and Kioti.
At the size you are looking at, if you stay with the major players, the tractors are all equally good. Consequently, you should be focusing on the dealership. What are they like? Can you get along with them? Are they willing to explain everything and let you test drive (at their place) the tractors and (most importantly) what is their service department like?
I went by the dealership tonight and talked to them about several of their options. He showed me a B3300 (I think), but said that the B series may be a little small for what I'm looking to do - he figured 32-38 HP was about right, but thought the platform of the B may be a little smaller than what I'd want to use. He then showed me their L3200 and L3800, which was what he said was probably the best fit for my needs. The 3800 with the quick disconnect FEL would be about 20,500 or so. Finally, he touched on the GL3240 and the GL3940. He thought these may be a little too large for my needs (harder to get into the brush, etc), but still in the range of acceptable for the work I was looking at doing. The GL3940 with FEL was about $26K.
His strongest suggestion was for the L3800, followed by the L3200 - his thought was that the 32 would probably fit most needs, but for the minimal cost difference (less than $1K) I should go for the extra power.
Everything he priced was new, and everything was Kubota brand (FELs). They had the quick disconnect buckets, etc.
I hadn't tried dickering with him, as I don't know how much he could/would discount from the price. My guess is there was some wiggle room in there, but I don't know what the ballpark pricing should be and I didn't want to start trying to dicker down until after I actually have the land and am ready to buy the tractor. There are three Kubota dealers in Louisville, so there's some competition. I have a Mahindra dealer about 25 miles away, a Kioti dealer about 15 miles away, and a JD dealer about 20-25 away. My guess is that I got quoted a slightly higher price than what they could do, with the expectation that I was going to shop and bargain hunt and they wanted some room for negotiations. That's just a guess, though.
He also showed me a 4in1 bucket from a 3rd party in North Carolina that can be used as a bucket, a blade, or a grapple (has 3000 lb of force). It and the connections would cost an additional $2000 (that's after a $600 rebate for trading in the bucket from whatever FEL I purchase). I don't remember the name, but I have it written down so will have to post it to see what you guys think...I am interested in the grapple function to try to clear out some of my back 2 acres.
On a side note, he pretty much mimicked your comments regarding the BackHoe and talked me out of buying and into renting on an as-needed basis (his idea was that if I found that I needed frequent rentals, then I should buy it, but wait until that's proven first)
Finally, what are your thoughts about buying used vs. buying new? And if I'm buying used, what should I be looking for (how many hours, wear in particular areas, common failure points, things that show that the tractor has been well-kept vs. abused, etc). I see that I could save significantly buying used online, and possibly 'upgrade' tractors. Is there a common spot that you guys go to check things out? I've only really found TractorHouse.com but am sure that there are other 'clearing houses' for tractors.
Thanks again for everything...I truly appreciate the advice and the education.
-Scott
/ Need Tractor Advice (and education) #28
If you are buying used and in doubt about inspecting it hire a professional to give it the once over.:)
/ Need Tractor Advice (and education) #29
I'll toss my 2 cents in as well, but for the most part I think you致e been given pretty good advice. You said something about mowing down near the creek what kind of clearance both width and overhead do you have? This will help determine the size of the tractor will it fit between the trees? As for the implements you mentioned (FEL, BH, bushhog, auger and finish mower) I'd start with the FEL and bushhog, and maybe the auger depending on whether you will need it right away. Get the others later after you decide you really need them.
As for bushhog size I run a 60 with a 23 hp L235. Just be sure the weight of any implement does not exceed the lift capacity of your 3 point hitch. Now a word on lift capacity. Most specs state the ability to lift a weight 2 behind the 3 pt hitch pins, but the weight of a 60 bushhog is farther back than that so it will have to weigh less than the 2 spec point.
As for the HST vs. gear. I have 1 HST type and 2 gear types. I prefer the gear. However the HST has better speed control than the gear type does. If you're going to be up close to objects the HST may be better, but if out in the field, then probably the gear.
I'd also get 4WD. Even for flat dry land. It increases your traction. Really helps with a FEL. A FEL will be much more useful than you can imagine. It is more than a powered wheelbarrow as was mentioned earlier limited only by your imaginagion as to how to put it to work. (e.g. I've used it as a scaffold :eek: and is much more stable than a ladder just be careful.)
You may also want to consider a canopy if you're going to be out in the sun for a long time.
/ Need Tractor Advice (and education) #30
If you do get the HST, and I think you are leaning that way, and if you are going to mow at a fixed ground speed for quite a while be sure to get cruise control for the HST. it was standard on my L3400HST. but I believe it is optional on the L3200 and the L3800, worth it if you go that way, If you go gear of course it is not needed or offered. As you just select your gear, and set the hand throttle and it stays there. Have you tried Barlows? They are in KY. for a quote, a lot of guys suggest that they are quite a bit cheaper on Kubota's than a lot of others. Would't hurt to get a quote.
James K0UA
James K0UA
thanks! i hadn't heard about Barlows but I'm checking them out now.
The bucket I was talking about was the UltraJaw2 4in1 bucket from W.R. Long. Haven't researched it yet, but from what the guy at the dealership said, it was a winner.
Thanks again.
-Scott
/ Need Tractor Advice (and education) #32
unless you are made of money i would look for a small used utility farm tractor to do the tractor work, and a good zero turn to handle the lawn, and would rent a back hoe as needed, if you are not in the building buisness or digging buisness the back hoe is just to expensive for the time you will use the piece.
contact me sometime and i will let you work some of my equipment to get a feel for what a tractor can and can not do, i live about a hour due south of the derby city
Thanks for that offer, and I'll probably take you up on it (more to see how someone is supposed to use a tractor than to learn much about the tractor performance...I think any tractor will out perform me at this point).
I've pretty much decided against the backhoe purchase, based on everyone's recommendations. If I stumble across a phenomenal deal, I'll bite, but otherwise I'll just end up renting for my uses.
I found out this afternoon that Kioti also has a dealership in town (it wasn't listed on Kioti's website, but they've been dealers for the last 7 years), about 9 miles from my new property. I swung by tonight not expecting anyone to be there, and while the doors were closed, a couple of the guys were out back loading something for delivery tomorrow morning. They stopped to talk to me for about 15 minutes, and they seemed like genuinely helpful and friendly people. I don't know if I'll go for a Kubota or Kioti, but I like the idea that I now feel like I have real options. Everyone seems to say that a good dealer is as important as a good tractor, so brand name isn't as important as a helpful dealer...if that's the case, this guy left a very good first impression. However, the DK40SE seemed like a slightly larger animal than I expected (the framework seems larger than the L3940s). I went out and looked at everything I have to do out there, and for the first couple years, I think I'm going to be doing a fairly high amount of pushing dirt/clearing trees before I'm down to 'mostly mowing'. That being the case, I thought that the stronger tractors may be more in line for my needs -- I could be wrong, though...I may just get lazy and figure that the forest can stay wild and I just need to mow the front acres and call it good. :thumbsup:
Any thoughts?
-handcuff
/ Need Tractor Advice (and education) #35
If you go the used route, you should be open to multiple brands. The major and middle of the pack brands are all good. If you are patient, and search hard enough, you may be able to find a better than average deal on a used tractor. Look for one that has been well cared for and, preferably, kept indoors.
I found just such a deal and am going to pick it up tomorrow. I'm getting a John Deere 4600 HST (43 HP) that is 10 years old, but has less than 450 hours of use. The tractor has a 460 loader and a 48 backhoe. The seller is very meticulous and said it has only been out in the rain twice in the 5 years he has owned it.
In my case, I considered new, but wanted a backhoe. Going the used route, I got the hoe and a larger tractor, for a bit less than I might have spent on a new 35 horse machine with only a loader.
I've been half-looking, and reading TBN, for years. I've been more seriously looking for a month or so.
Did anyone suggest TractorHouse.com? New or used, TractorHouse can give you a feel for what the pricing should be.
Thanks for the feedback, Dennis. I've been seriously considering used also, especially based on my budget. I'm also contemplating what items I should get used vs new (based on availability, how much impact being 'used' will have on a particular device, etc). Everything is priced somewhat "ballparkish" (I can find prices cheaper than these, but these are an average of what I think I could get reasonably easily). Also, these all include an FEL, as I believe I will need an FEL immediately.
Here's the choices I seem to be landing around, based on my research/budget/needs:
Used:
Kubota L3130 for ~14K (saving a chunk of money for future attachments) - about the least amount of HP I want to go with.
Kubota L3830 for ~18K (not much for future attachments, but I could go used for attachments and get most of what I'd like to have)
Kubota L4400 for ~20K (no money left for attachments...will go beyond my current budget for getting what I need, but it may be worth it)
Kioti DK45SE for ~18K (minimal left over, but a newer 'used' machine with some significant HP)
New:
Kioti DK35
Kubota L3800
Things I'd need to get soon:
60" or 72" BushHog (needed immediately)
72" Rototiller
Grapple Bucket
Things I'd like to get someday:
Boxblade/grater
Finish Mower
Post Hole Digger
Cab (can you add these later, or do you need to buy a machine with an existing cab?)
So do you guys think I should go new and buy smaller (and have a warrantee) or buy used and get something a little stronger/bigger/whatever.
Thanks again for the help and continued education.
-Scott
/ Need Tractor Advice (and education) #37
I haven't checked prices this year but when I bought my JD 5103 (45HP) with FEL, boxblade and 6' Mower I came in at ~$21K. Now this model doesn't have a lot of bells and whistles as it's a shuttle shift but I was looking for where it counted. Lots of grunt work and easy on the fuel. I purchased mine in 2008.
Good luck.
/ Need Tractor Advice (and education) #38
New versus used can make for sleepless decision nights.:thumbsup:
It's the faith you have in yourself to access used value and condition that count.:)
/ Need Tractor Advice (and education) #39
it might sound odd but i could never justify spending 20000.00 on equipment for a 7-50 acre place
a good used tractor can be bought for much less, i had a friend today price me a good little 2000 ford tractor bush hog,plow, disk, grader blade, and something else that i can not recall for $3200, for the package, and i know it is a good tractor. it has good rubber, and runs excellant
a good finish mower can be picked up in the 4-500 range, and post hole diggers for 125-200 used,
/ Need Tractor Advice (and education) #40
Hi Dennis,
If you don't mind I'd sure appreciate knowing how much you settled for on for that JD4600. I'm in Oregon and a 'friend of a friend' heard I was in the market for that size tractor and he said he'd let his 10 year old 4600 with the 4600 loader and back hoe go for around 15K...unfortunately it has 2200hrs on it although the guy is known to look after his equipment. I haven't seen it yet but plan to soon.
Hope yours is working out for you!
Rgds,
Gray Goodman
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2020 Crown Concrete Mixer (A65579)
2020 Crown...
78in. Skid Steer Bucket w/ Blade (A65640)
78in. Skid Steer...
26 Gallon Dewalt Air Compressor (A65579)
26 Gallon Dewalt...
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
