Need some help
/ Need some help #1
Iain15
I have a YM336D in which the ignition switch has become loose. There is a stainless steel or chrome bezel with two small holes opposite each other that seems like should come off to reveal a retaining nut. Is this correct and if so, is there some special tool that is necessary to accomplish this.
Any help is appreciated,
Iain
/ Need some help #2
There is a special tool but I don't know where you could get one. Usually we just use channel locks. Wrap a rag around the nut to keep from scratching it if you want.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Need some help
Many thanks. I'll try it today.
Iain
/ Need some help #4
I think the special tool is Snap Ring Pliers that come in a variety of sizes and quality. The tips turned 90 degrees fit into those two holes, but as mentioned, you can make do with other pliers in most cases.
/ Need some help #5
If you don't have snap ring pliers try needle nose.They would be less likely to bend or break.then use something in between the handles for leverage.
/ Need some help #6
I took this picture a while back to illustrate that the replacement switch uses a different key.
Are you talking about the bezel on this old (removed) switch? The bezel itself is the retaining nut. Like Aaron said use Channellock pliers. Shielded with a rag, or electrical tape in the pliers' jaws.
/ Need some help #7
I seen yours Cal. and its was like wait a dang min. I know I used needle nose pliers someone must have just notched it.
/ Need some help
Yes Cal, just like the one on the left. I ended up using channel locks and only scarred it a little. It seems tight on the switch but the switch and bezel together still have a little play so I may have to add some gasket/washer material. Thanks to everyone for your help.
Iain
/ Need some help #9
Iain
There is supposed to be a fiber washer between dash and switch. Sometimes it wears, breaks, and falls out. Use gasket material, neoprene, etc. to make one.
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
213101 (A64276)
213101 (A64276)
2018 Hydrema 912F Articulated Dump Truck (A64553)
2018 Hydrema 912F...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
500 GALLON FUEL TANK (A64278)
500 GALLON FUEL...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
