need help
/ need help #1
colorblind
billings missouri
kioti ck30/with loader
I just had a limb wedge up against my foot throttl bracket. it caused my cable to open the throttle. The tractor just shut off immediately. I repaired the bracket and the throttle cable is in the idle position but I can't get the tractor to start. It is turning over just fine it just won't start. I have plenty of fuel in the tank. any thoughts would be greatly appreciated /forums/images/graemlins/confused.gif
/ need help
/ need help #3
Hello Colorblind, Where did this limb hit your tractor, from underneath or on top of the floor board? Matt
/ need help #4
/ need help #5
Are you talking about the HST pedal? ...i thought you said that you bought the HST....could be wrong.
/ need help #6
/ need help #7
Check that the fuel cutoff solenoid is working and that the manual fuel cut off cable did not get pulled somehow.
/ need help #8
/ need help
It is the manual transmission. The limb hit underneath. There is a small bracket that the throttle cable attaches to that bent just enough to extend the cable some. I bent the bracket back where it is suppose to be at and both throttle cables are fine and in the idle position. I am not sure that I didn't get some bad diesel fuel I had filled up about 20 minutes prior to the incident. thanks /forums/images/graemlins/confused.gif
/ need help
/ need help #11
Also check to see if the cable on the "kill pull" got pulled on. That's the red knob below where the key goes for cutting off the fuel solenoid for an emergency cut off. If that got bent, it could be keeping the tractor from starting.
John
/ need help #12
John
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A67714)
2011 FREIGHTLINER...
2025 16in Tooth Bucket Mini Excavator Attachment (A66734)
2025 16in Tooth...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2010 . TRIAXLE LOWBOY (A67714)
2010 . TRIAXLE...
Jack Daniels Metal Decorative Sign (A66738)
Jack Daniels Metal...
