Need help with my throttle slipping
/ Need help with my throttle slipping #1
NM_Mike
South-Central, NM
New Holland TC33
I have a TC33D that I can't keep the throttle still, it keeps slipping back to a lower RPM. I have looked under the hood to see if there was something I could tighten up, but I can't even figure out where the throttle wire comes out of the firewall and what it hooks to. I surely don't want to take a part the dash if I don't have to.
Can someone help me figure out how to put a little friction on the throttle cable?
Thx, Mike
/ Need help with my throttle slipping #2
You have to take the 2 plastic pieces off underneath the dash. The two black pieces that are on either side of the lever that controls the tilt of the steering wheel. There are 2 bolts that hold them together. Once you remove these, you will be able to see the bottom of the throttle handle. Tighten the nut and then put a lock nut on the shaft. Alternativley, you could use some thread lock.
/ Need help with my throttle slipping #3
Using a search you will find many more detailed answers than mine...
You need to take off the right side of the dash (the part the key switch is in). The throttle level has a friction disk and you just need to tighten it up (pinching the disks). I ended up adding a little lock tight to try to keep it from loosing up.
When I took my cowl off, I found that a couple of the bolts were loose so I'm glad I did the 'repair'.
- Eric
/ Need help with my throttle slipping #4
We used a drop of thread locker like MikePA recommended and haven't had a problem since. Tightening the tensioning nut is fairly easy and shouldn't be a problem for you.
Thanks everybody. I give it a go tomorrow.
thx again...Mike
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
(APPROX.64) 2X6X8 NO.2 PRIME LUMBER (A60432)
(APPROX.64) 2X6X8...
2013 Ford E-250 Cargo Van (A59230)
2013 Ford E-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED IRANCH IRLMB HYD MINI CONCRETE MIXING BKT (A60432)
UNUSED IRANCH...
