Need Help with BX-24
/ Need Help with BX-24 #1
Harlan B
New Franken Wi
Bx-24
I recently bought a used BX-24 from a private party. This tractor was never stored inside. The owner did not have a mower for it and he never used the three point hitch. The problem I have is the the three point hitch lowering speed knob and the cutting height control knob do not turn. Did anyone ever have this problem? How does one get them freed up? Once the knobs go through the bonnet you can't get at them from underneath. Any suggestions will help.
Thanks
Harlan
/ Need Help with BX-24 #2
This product has saved my bacon more times than I can count. Spray liberally with wand. Try to soak all threads and allow to soak overnight. Don't be shy about it applying it to all fittings, threads, sockets, levers, everything.
Breakawayï½® Penetrating Oil - TP Tools & Equipment
It needs to work awhile. Don't rush and don't break anything! :)
It sounds like sitting out in the weather has not been kind to it.
/ Need Help with BX-24 #3
you also need to have the height in the up position to adjust them.. atleast on my BX-2350 you do... so you would need to raise the 3 pt and the mid mount up, then the height adjustment should move....... goodluck!
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
CAT 963C GP Bucket (A68134)
CAT 963C GP Bucket...
2025 28in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 28in Forks...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
