Need Help with BX-24
/ Need Help with BX-24 #1
Harlan B
New Franken Wi
Bx-24
I recently bought a used BX-24 from a private party. This tractor was never stored inside. The owner did not have a mower for it and he never used the three point hitch. The problem I have is the the three point hitch lowering speed knob and the cutting height control knob do not turn. Did anyone ever have this problem? How does one get them freed up? Once the knobs go through the bonnet you can't get at them from underneath. Any suggestions will help.
Harlan
/ Need Help with BX-24 #2
This product has saved my bacon more times than I can count. Spray liberally with wand. Try to soak all threads and allow to soak overnight. Don't be shy about it applying it to all fittings, threads, sockets, levers, everything.
Breakawayï½® Penetrating Oil - TP Tools & Equipment
It needs to work awhile. Don't rush and don't break anything! :)
It sounds like sitting out in the weather has not been kind to it.
/ Need Help with BX-24 #3
you also need to have the height in the up position to adjust them.. atleast on my BX-2350 you do... so you would need to raise the 3 pt and the mid mount up, then the height adjustment should move....... goodluck!
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
2007 JLG 660SJ SKYPOWER TELESCOPIC BOOM LIFT (A65056)
2007 JLG 660SJ...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
HOSES (A68842)
HOSES (A68842)
