Need help replacing belts
/ Need help replacing belts #1
dcarroll
Rock Island, TN
Cub Cadet
Need help on how to replace worn out belts on 66 inch Swisher trail mower
/ Need help replacing belts #2
They are pretty straightforward usually and many times sized to where you can install a Gates green belt or something similar. Manuals
/ Need help replacing belts #3
check for your model number and download the manual here - Search Results
/ Need help replacing belts #4
If you go with generic belts make sure they are Kevlar.
Regular belts don't hold up to punishment on lawn equipment.
/ Need help replacing belts #5
I've had the 66 inch since they first came out. The belt I had a tough time replacing at first was the drive belt. Wasnt enough clearance for the belt to go
under the engine shaft. Trick is to loosen the 2 bolts on the plate the engine sits on, and pry the plate up a tad. The bolt holes are elongated for this. I use swisher belts, haven't found 133 in belts anywhere else.
lar
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
2022 EZ-GO ELITE...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
