Need help replacing belts
/ Need help replacing belts #1
dcarroll
Rock Island, TN
Cub Cadet
Need help on how to replace worn out belts on 66 inch Swisher trail mower
/ Need help replacing belts #2
They are pretty straightforward usually and many times sized to where you can install a Gates green belt or something similar. Manuals
/ Need help replacing belts #3
check for your model number and download the manual here - Search Results
/ Need help replacing belts #4
If you go with generic belts make sure they are Kevlar.
Regular belts don't hold up to punishment on lawn equipment.
/ Need help replacing belts #5
I've had the 66 inch since they first came out. The belt I had a tough time replacing at first was the drive belt. Wasnt enough clearance for the belt to go
under the engine shaft. Trick is to loosen the 2 bolts on the plate the engine sits on, and pry the plate up a tad. The bolt holes are elongated for this. I use swisher belts, haven't found 133 in belts anywhere else.
lar
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
Shoup John Deere 918 Poly for Platform (A65640)
Shoup John Deere...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
