1946 oliver standard 60 Fan/water pump belt
/ 1946 oliver standard 60 Fan/water pump belt #1
cptmiker
Hello all I am trying to replace the fan/water pump belt and I can not figure out how to get it off. I removed the fan bolts but can not get the fan pulley off as the water pump shaft is too long to get it off with the tension on the belt any suggestion of if anyone has a manual that can explain how to get it off.
/ 1946 oliver standard 60 Fan/water pump belt #2
Hemm is this the correct way to do this or a workaround? I am willing to try anything but want to do it the correct way.
/ 1946 oliver standard 60 Fan/water pump belt #4
I spent a lot of time on a 60 when I was a kid, about 55 years ago. If my Dad was still alive, he could probably help you.
/ 1946 oliver standard 60 Fan/water pump belt #5
Generally this belt also drives the generator. If yours also drives the generator it's a simple matter to loosen the generator mounting bolts to release tension on the belt and slip it off. Replace the belt, apply tension, and tighten the bolts.
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
UNUSED IRANCH 20CM TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 20CM...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2007 CHEVROLET SILVERADO K1500 CREW CAB TRUCK (A60430)
2007 CHEVROLET...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
UNUSED FUTURE HYD THUMB CLAMP -D60450 (A60432)
UNUSED FUTURE HYD...
