Need help replacing belts
/ Need help replacing belts #1
dcarroll
Rock Island, TN
Cub Cadet
Need help on how to replace worn out belts on 66 inch Swisher trail mower
/ Need help replacing belts #2
They are pretty straightforward usually and many times sized to where you can install a Gates green belt or something similar. Manuals
/ Need help replacing belts #3
check for your model number and download the manual here - Search Results
/ Need help replacing belts #4
If you go with generic belts make sure they are Kevlar.
Regular belts don't hold up to punishment on lawn equipment.
/ Need help replacing belts #5
I've had the 66 inch since they first came out. The belt I had a tough time replacing at first was the drive belt. Wasnt enough clearance for the belt to go
under the engine shaft. Trick is to loosen the 2 bolts on the plate the engine sits on, and pry the plate up a tad. The bolt holes are elongated for this. I use swisher belts, haven't found 133 in belts anywhere else.
lar
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
2012 MACK GU GRANITE 6X4 T/A ROLLOFF TRUCK TRACTOR (A59914)
2012 MACK GU...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
17601CFL (A59228)
17601CFL (A59228)
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
