Need help replacing belts
/ Need help replacing belts #1
dcarroll
Rock Island, TN
Cub Cadet
Need help on how to replace worn out belts on 66 inch Swisher trail mower
/ Need help replacing belts #2
They are pretty straightforward usually and many times sized to where you can install a Gates green belt or something similar. Manuals
/ Need help replacing belts #3
check for your model number and download the manual here - Search Results
/ Need help replacing belts #4
If you go with generic belts make sure they are Kevlar.
Regular belts don't hold up to punishment on lawn equipment.
/ Need help replacing belts #5
I've had the 66 inch since they first came out. The belt I had a tough time replacing at first was the drive belt. Wasnt enough clearance for the belt to go
under the engine shaft. Trick is to loosen the 2 bolts on the plate the engine sits on, and pry the plate up a tad. The bolt holes are elongated for this. I use swisher belts, haven't found 133 in belts anywhere else.
lar
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Pallet of Chains & Binders (A64127)
Pallet of Chains &...
