TexasOaks
New to tractors and I dont know if this is a good roller or not or if it is a good deal or not? It is a pin hitch and weighs 400-450lbs. They are asking $150. We just purchased a JD 4300. Any feeback is appreciated. Thanks
RoyJackson said:It doesn't look heavy though....
srjones said:Is it a good deal? Well, the answer depends on a few questions:
1. Does it roll, or is it badly rusted/siezed. Is there any place to grease the bearings?
2. Is it straight (unbent/undamaged)
3. Do you have any metal fabrication skills and a desire to build it yourself? A well casing filled with concrete will get you pretty close to that.
4. How badly do you *need* a roller?
To me, $150 seems a little steep, but then again I don't *need* a roller.
TexasOaks said:its not real close to where I live.
srjones said:For those of us not in TX, can you translate that to miles?
A few more thoughts on your questions...
If you're using this to flatten a seedbeed, there are black plastic lawn rollers (water fillable) that go for under $100.
Also, contact the CL poster just to let them know you're interested. It may already be sold, and this discussion is moot.
Anyway, good luck.![]()
srjones said:Go to some place like NothernTool ( Pressure Washers, Portable Generators, Mowers, Lawn + Garden | Northern Tool + Equipment ) and search for "lawn roller".
I bought a smaller one at HomeDepot about 8 years ago and the price hasn't seemed to go up that much.
kennyd said:Check out TSC if you have one in your area.
I had a 4' plastic roller for a while, and I would not get a plastic one again for smoothing, the plastic just gives way to hard objects, and it got a large flat spot on it from sitting with water in it.
IMHO, a steel roller will serve you better. The TSC near me sells 4' and a 5' steel rollers.
srjones said:400-450 lbs ain't exactly light..![]()
kennyd said:When it's spread over 8' it isn't exactly heavy for a roller either![]()
CFHartman said:I don't like the small dia. 10" . I think I only saw a pipe brg. I think you will have trouble getting it to roll in fine tilled soil like a seed bed.
