Need Help identifying Deere 750B Dozer Part
/ Need Help identifying Deere 750B Dozer Part #1
Tanamera
Gordonville, Texas
2008 Kubota MX5100 (Gear) LA 844 FEL, 1952 Ford 8N, 1988 John Deere 750B Crawler Dozer
I think I finally found the hydraulic fluid leak on the 750B I recently purchased. This appears to be some type of spin-on filter housing. Can anyone tell me what this is? I am hoping there is an "O" Ring that has failed. It is located at the right rear of the bulldozer.
Here is a wider-angle view so you can see where the part is on the dozer.
/ Need Help identifying Deere 750B Dozer Part #3
I hired a guy that had just become the proud owner of one of these. One hose after another blew! After he was done my project, I understand the blowouts continued. Finally, I understand one of the hydrostat motors failed, leaving the machine sitting and abandoned in his yard!
Are these machines a lemon of sorts?
Hopefully not. Have done many hours of work and have blown only one hose.
Have any idea what the part is?
/ Need Help identifying Deere 750B Dozer Part #6
I don't know anything about these critters. Just a wild guess. First impression is its a filter and if not that a second guess would be an accumulator.
/ Need Help identifying Deere 750B Dozer Part #7
the transmission oil filter looks to be the only element type filter on the 750B
/ Need Help identifying Deere 750B Dozer Part #8
Sure does LOOK like a filter. You tried to see if it would spin off ?
I talked to John Deere and the transmission filter they show is a straight spin-on filter. This one looks more like a housing and the schematic that "joecdeere" posted looks like an element under a housing. i just wanted to make sure what I was working on.
Anybody replaced one of these?
/ Need Help identifying Deere 750B Dozer Part #11
You might try asking these guys - They know dozers pretty well
Dozers
I posted on HeavyEquipment too. Have not gotten much help so far.
/ Need Help identifying Deere 750B Dozer Part #13
There's a serial number break for trans/hyd filter eariler model had spin on as in this parts photo. Later serial # had canister type. Here's the SN break:TRANSMISSION OIL FILTER(SERIAL NO. 731274- )
Thanks Guys. I got the filter and "O" Ring. I will install this weekend. I hope this solves the leak issue
