Need help buying a mini excavator
/ Need help buying a mini excavator #1
Botabill
Platinum Member
Ontario
I am looking for a mini excavator. For the little I plan to do with it I'm not sure I can justify buying new so I've been looking for a used one. My main purpose is to dig out stumps of buckthorn that may have three or four stems in them up to 3 inch in diameter each. There may be a few elm stumps and they can be up to twelve inches across. I will also be using it to trench through heavy clay with lots of rocks down to 5 feet It isn't going to be used commercially just periodically in a rather leisurly fashion around my farm. I will probably get a Kubota because I have a Kubota tractor and a dealer in my area. My questions are: 1/ At what point on the hour meter do you feel a machine has really passed it's trouble free operating age. I've seen machines advertised that the seller said was low hours only to discover he thought 3000 hours was low. I'm not sure that is what most people would consider low. 2/ Which mdel of Kubota would you recommend? and 3/ What other makes should I consider or avoid? Thanks!
/ Need help buying a mini excavator #2
I own several Bobcat 325 Mini excavators, they are good machines with Kubota engines in them,depending on what size you are looking for the 325 would have a hard time digging 5'-deep in hard clay it's just too small for that.I can tell you that a new 325 machine will cost around $ 34,000 new I just bought one and a used one will sell for about half of that with 3000 hours on it.You can get parts for the Bobcat from Kubota as far as engine parts all the other parts would have to come from Bobcat, but the have good parts support.I hope this information helps you.
Tommy
/ Need help buying a mini excavator #3
I purchased my Kubota excavator for the same reasons you are looking at Kubota 1) have a Kubota tractor 2) dealer support. If you said the same about Bobcat I would also agree with you. The sizes that would work for you are a couple but I would have to go with what I have a KX91-3. You might find it is a little overkill or too small. What I would do is go out and try a few different sizes first so you know what to look for. Once you know the size that will work for you then you can really start looking. Nothing worse than to buy the wrong machine for the job /forums/images/graemlins/frown.gif . The amount of hours really means little unless it is truly excessive. Some machines with no maintenance are worn out at 1000 hours and some with 3000 are good for many more. Myself if I was going to buy used I would like to be under 2000( if hours were my main concern) so it will still have good value when I am done with it. The price is still the main thing in the decision to purchase though. Remember the hour meter could be turned back if someone really wanted to. The big problem is the cost of repairs to these machines, tracks are $2300 cdn each from Kubota( have two new never used I will sell reasonable /forums/images/graemlins/smile.gif),drive motors will set you back $5000 each, replacement cylinders can be $2500 each, anyhow you get the idea. The best thing to do is to take a person who knows these machines to go with you. If that is not possible take lots of pics and post them here for members opinions. The things to look at for example are tracks, sprockets, rollers, guides,coolant color-condition,looseness of arm- bucket to figure pin bushing wear, hydraulic leaks where and how many, overall condition of hoses lines etc and the bucket for wear and to help make a assessment of use ~ hours used. If you buy from a dealer try and get at least 30 days warranty. As far as other makes go I would only buy what you can easily get parts for. I owned a Daewoo and parts were not hard to get just time consuming and more expensive then common makes. With the high cost of repairing these machines a couple dollars saved can be spent real quick with just one repair. Any other questions just ask, my opinions are priced at what they are worth "nothing" /forums/images/graemlins/grin.gif and I hand them out to whoever wants them.
Thanks for the comments guys. There was a KX91-3 for sale in Ontario not far from where I live this week. It had about 50 hours on it. It looked almost new. It sold real quick for $33,000. That was one heck of a buy for someone. I couldn't justify that much money though for what I had planned. How about digging out 12 inch stumps? Or 5 feet ditches (going slow) in heaavy somewhat rocky clay. Would a smaller Kubota do that. I think there is a KX 41 or 61?
/ Need help buying a mini excavator #5
I have a Kubota L 48 and have spent the last five weeks removing tons of stumps between 8 and 25 inches on our 26 acres. I have the mechanical quick attach hoe system and use a 12" bucket for stump removal. When removed and piled, the front end loader makes quick work pushing them to the burn pile... I have three hundred feet of trench to finish digging for my sister in laws underground elec/cable/phone. We have rocks, boulders, ledge, and a million more rocks and the 48 does fine.. New England area which is very similar to your geologic area..
How long do you think it would take your L48 to dig a 350 foot trench 5 feet deep LarryRB.
/ Need help buying a mini excavator #7
depends waht you run into, a good day would do it unless there is a boulder the size of a house or somethng like that
/ Need help buying a mini excavator #8
I have been using grey Market machines for several years. I have had very good luck so far. I use them for installing plumbing in clay soil. I have had Yanmar and Kobelco machines. I used the Yanmar for 3 years. I was able to bill out enough to pay for it and then I sold it for what I had paid for it originally. $10,000. It was smaller than the Kubota they are talking about but it would dig about 7" deep. There are several grey dealers in Cnanda. If you do your research you can get a grey that has a match up with a domestic model making parts easy. Kubota also has several grey/domestic models. Hours wise, 1 to 2000 hours on a grey is not too hard to find. My Kobelco had 1100 when I got it. I will attach a picture of the PC 40 Komatsu my son is working. It is a grey with 1500 hrs when we got it.
/ Need help buying a mini excavator #9
this might be a dumb question. i thought grey machines were not native to the usa? don't they sell kobelco in the us.?I see alot of them.. just wondering.
circleT /forums/images/graemlins/smile.gif
/ Need help buying a mini excavator #10
There are models with standards for specific countrys. A US Kobelco isn't grey. A model made to Japanese standards and sold first in Japan is. Some brands are painted differently also. Even Cat has Japanese models that are considered grey here.
/ Need help buying a mini excavator #11
I have a Bobcat 430 excavator with steel treads. It weighs in at 8100 lbs & is in the class of the Kubota 121. I have a Kubota M5700 tractor I bought new & went to the same dealer for the excavator. He said he could get parts for the bobcat faster than the Kubota. At that time, bobcat was offering 3.9% interest for 48 months. I traded in a woods 9000 backhoe which was practically new. The bobcat felt real tippy at first but I'm getting used to it, but still have much to learn. It set be back about 45K.
/ Need help buying a mini excavator #12
I'm not on a soap box, just adding info. As a comparable, a Komatsu PC-40 / 8900# grey market unit with about 1300 hrs, you can expect to pay less than $20,000 US.
/ Need help buying a mini excavator #13
Yup,, I have 2 98 model PC40-8 w/ steel tracks and rubber pads (no rubber tracks) for sale and they are under $20K.
Darin
/ Need help buying a mini excavator #14
20050919
Montana Jack, let me know if you are still monitoring this forum. I just bought a cwt for my 430 (tippy, I agree, when pushed to its limits) which should help. I'll report on it if you remind me (has not come yet).
Jim
Mt Burgha on the Rivanna in VA
/ Need help buying a mini excavator #15
Jim,
I'd be interested in any info you could give me on that couterweight option. I didn't even know such a thing existed. The tippiness of the 430 is the only negative I have so far, but believe it will be less of a factor as I gain more experience. Thanks, Jack.
/ Need help buying a mini excavator #16
20060304
HI, Jack,
Sorry to be so long in responding.
I've installed the cwt in my 430 and here are my observations:
1- It was a bear to put in, with space tight. I had to tinker with the latch several times, and it is still too tight. I'd get the dealer to do the install, prob worth the money.
I may wind up trimming some of the tail door insulation to alleviate the tightness, or may wait to see what the dealer's mech says next time I take it in.
2- My perception is that noise is worse since I went "heavy". Especially in the lower ranges.
3- When I first used it after the install, I found things more stable, less wobble, etc, when slinging heavy buckets of wet mud & sand out of a catch pull before my pond. Normally I would experience a lot more shaking, etc, before I installed the cwt.
The real test will be using my wainroy, around 200# of side-to-side swinging add-on. Haven't used it yet.
But, overall, a good thing, just not perfect.
HTH, Jim
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
MAC STRIPPERS POWER MAC JR LINE PAINTING TRUCK (A63276)
MAC STRIPPERS...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
