Need Commander 6000 info
/ Need Commander 6000 info #1
dieselcrawler
Elite Member
Lucasville Ohio
2013 JD 3005 2001 Kubota BX1800
Hello All,
I have recently traded an old truck I had for a mid-60's Ford Commander 6000 tractor with the select-o-speed tranny. The former owner drove it to my house, but the hyd lift system and brakes are not working. It is my understanding that this tractor uses a accumulator tank and hyd pump type system to operate these things, any one have any advice for me?
The tractor seems to run ok, shifts ok, they fella I got it from used it sparingly, it's a big tractor. Huge, since I grew up on a MF135. I need to check for proper operation of the intake heater/glow plugs system, doesn't start w/o ether, and I don't like to use that on my diesels.
I just signed up with this BB forum, I'll list my info in my sig soon, but for now....
I'm in New Martinsville West Virginia, south of Wheeling WV.
Thanks for any info anyone might have...
Greg Hughes AKA dieselcrawer
/ Need Commander 6000 info #2
ok ive got a question for you.can you raise an lower your 3pt lift arms.since you have no brakes on the tractor.im betting that the hydro pump is out on the 6000.talk to manchinic an see if he will help you with the tractor.the hydro pump needs overhauling from the sound of things.my dad has overhauled the hydro pumps a few times.but he is gone so i cant ask him qs on things ive forgotten.
/ Need Commander 6000 info #4
I hope the probs are in non tranny related areas... as the linked post will show.. the 6000 is ford's red headed stepchild.
yes.. the hyds used an accumulator so you could have limited use of the lift after shutdown..
soundguy
/ Need Commander 6000 info #5
Ag's version of the EDSEL! it might have value to ford collectors, if it has the right sequence of paint jobs.:D
/ Need Commander 6000 info #6
The other thread was quite interesting, I had heard very little about the SOS tranny.
There's a 1961 6000 on ebay right now in Indiana. Claims to be a low hour rig.:rolleyes:
/ Need Commander 6000 info #7
Low hour...I bet. most of them had to be low hour due to the highly reliable transmission ford put in them...
soundguy
My 6000 is one of the blue ones, and the lift arms don't work, as well as the brakes. I will be looking into the accumulater once I get it starting/running ok. Powersteering seems to work, looks like it uses the same hyd fluid supply tank, but has it's own pump?
Thanks for your replies.
Greg
/ Need Commander 6000 info #9
Greg
All of the original red 6000's were recalled and "fixed" and when done they were returned painted blue so there "shouldn't" be any red 6000's left but we know how recalls go:rolleyes:
Good luck with your tractor. Regardless of their history they are a unique tractor that I would love to own some day.
/ Need Commander 6000 info #10
I show the PS pump for the 6000 as P/N
C3NN3A674A PUMP, HYDRAULIC Pump Assy., Power Steering, Years: 01/01/1961-12/31/1967
C7NN3A674K PUMP, HYDRAULIC Pump Assy., Power Steering, 1100 P.S.I.-287 U.S. Gal. at 1,000 R.P.M., L/External Gear, Includes: Ref. 1 thru 36, Start Year: 04/01/1967
C7NN3A674K PUMP, HYDRAULIC Body, Power Steering Pump, Replaces C5NN-3N591-C, Start Year: 04/01/1967
As for resv, I show the following:
D2NN3531B TANK Reservoir Assy., Power Steering Pump, Replaces C5NN-3531-B, Includes: Body & Ref. 2 thru 10, Start Year: 04/01/1967
C5NN3N577B Body & Bracket Assy., P.S. Pump Reservoir, Start Year: 04/01/1967
C7NN3N538A FILTER, ELEMENT Element, P.S. Pump Oil Reservoir Filter, Replaces C5NN-3N538-B, Start Year: 04/01/1967
soundguy
WOW, thanks soundguy, for the detailed info, part numbers and all...
As to the older red ones, even if what I have is older, you'd think there would be some evidence of the re-paint work... I'll look closely, but I think I have one of the later ones. I need to look up the numbers on the tractor, see what year it is... I found a list of how to read them by searching here somewhere...
I took my exhaust pipe off at the end of the manifold... it's rusted out in the bend it makes to go up to the muffler. Looks like I'll need a new gasket at the flange from the manifold to the pipe... I'm gonna re-route the pipe down and under the tractor, I will be brush hogging under low hanging branches when I do get the ol' beast working good... no exhaust coming out of the hood will be better... have to find a muffler also...
/ Need Commander 6000 info #12
Post the #'s from the bellhousing.
soundguy
soundguy
I finaly got the numbers from the bellhousing by the starter, on the left side of the tractor.
61107-5-D
and just below it is
(diamond) 21696 (I think another diamond)
On the motor it's self, middle of the block, by the water jacket drain, is this:
C3NN-6015-0
and below, faintly, on a cast/raised place, suppost to look like a tag and screw heads, reads as below, without spaces:
3 8 or B 2 0
on the back, under the seat, on what I guess is the hyd lift system, are some numbers, but the valve block for the wet lines to the rear cover part of the numbers... however, what i can see is this:
NNA857-E
and farther across, more faintly, is O. l. 3.
any info would be awesome.... thank you in advance...
/ Need Commander 6000 info #14
Brought my 6600 manual home instead of my 6000 by mistake.
will try to get those numbers tracked down for you anyway this weekend.
( appears to be a 1964 SN )
soundguy
The former owner also told me he thought it was a 1964 model year tractor...
How does the SOS trans fit into that, as in, what year did they stop making the junky one? I was under the impression that the later-model year tractors were fairly reliable, but sold poorly due to a ruined reputation...?
Otherwise, I can most likely fix the other issues... hyd system, exhaust system... and from what I've been told it seems to be working smoothly, according to the former owner. Myself, I've drivein it all of about 150 feet the one time I've had it running about a month ago...
Soundguy, thanks for takin' the time to look up stuff for me... I'm courious what kind of info you'll have access to...
/ Need Commander 6000 info #16
Reliable generally wasn't an often used term with ANY of the SOS trannies. "Dependable to a point as long as you took extremely good care and held to a strict maintenance program" was more the story line. Part of the issues the 6000 SOS had was they were at the upper end of the horsepower scale for 1960's SOS technology to deal with. Even the "good ones" had their troubles when used hard. Way back when the 6000 was still a new tractor, the biggest, newest tractor on the farm was almost always the primary tillage machine. Most 6000's generally weren't bought for light duty chores. 6000 SOS's weren't the hot set-up for that sort of use at the hands of MOST people. They could handle the job, IF....if every preventative maintenance step was followed and done correctly, and they weren't ABUSED. When an SOS works, they work so easily that people tend to think "out of sight-out of mind" as far as maintenance. Also, most early SOS buyers were pre-conditioned with years of "gear" technology where an oil change every 20 years or so, need it or not, was good enough.
A neighbor of mine has a 4000 SU SOS with over 7000 hours and NO tranny issues. (And I would give my eye teeth for.) They can be made to hold up. When they do, it makes for one VERY handy tractor. When you get one that's been improperly cared for (ie NOT cared for) you have a rolling money pit.
Thanks for your input, FWJ...
So what would be the recomended maintnance schdule? What kind of things need to be done to keep this ol' critter goin'?
I doubt I'll ever use this tractor "heavily", just need to be able to do some brush hoggin', and pick-pole to lift/move my junk truck collection around... maybe some grader blade work from time to time to keep the road up... don't think it's ever gonna pull a plow... might use it in the hayfield sometimes... might look into a FEL at some point...
/ Need Commander 6000 info #18
Clean oil and filters.
Owning the insert from the manual that involves the care and feeding and diagnostic info will be usefull ( you will need to make adjustments when you check servo's and clutches.. etc.. ), as well as a set of gauges so you can check pressure onthe servo's.
soundguy
/ Need Commander 6000 info #19
Hey Bob...I have a Ford 6000 here in Forestville....it is a fun tractor to pull...took it to Stockton last summer as well as South Dayton...won the 9000, 9500 and 10,500 class
/ Need Commander 6000 info #20
7yr ok thread, but you could pm rob
SDlanch SSL60 (A64912)
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
PALLET OF CUT-OFF VALVES (A67714)
PALLET OF CUT-OFF...
2008 MISSISSIPPI BOTTLE TRAILER (A67714)
2008 MISSISSIPPI...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
