Need advise.
/ Need advise. #1
2013 BX2670
I have a kubota 2370. I would like to get a rear 3pt snowblower. Looking for your input. What you have and how it is working for you. All opinions are welcome. ThankYou
The 2 I am considering now are Woodsmaxx 48 and Bercomac 56? They are fairly close in price, the berco is a little higher. I kind of like the belt drive idea. And I must have electric Shute controls. I have a cab and am too lazy to get out every time I will need to adjust it.
/ Need advise. #2
You may have already considered this, but unless you're prepared to remove snow while backing up you may wish to consider a front mount blower.
/ Need advise. #3
Kubota 2370 or 2670??? The 2670 will have more power to deliver to a PTO driven, 3pt blower. However, either tractor should be able to adequately power a 56" blower.
/ Need advise. #4
I don’t know specifically about those blowers, but if a blower is belt driven, I’d be concerned about snow/ice causing slippage or other problems with the belt.
When you’re blowing snow, the least amount of problems, the better.
I’d stick with chain or gear driven
Just my opinion
/ Need advise. #5
56 or 60" would be a good match and as stated earlier, chain or gear drive would be best. Ken Sweet
/ Need advise. #6
Do not get a rear blower they are the worst to use as you will ALWAYS have to be turned around in your seat. Your back and neck will thank you to get a front blower.
/ Need advise. #7
suggest just getting a front snow blade. little to no maintenance and snow removal goes fast
/ Need advise. #8
I blow a lot of snow (LOTS!) and the snow I blow is on the drier side so I rarely fight with wet / sticky snow. Used to blow with a B2620 w/ 60" blower and now I blow with an L3301 w/ a 66" blower. Always rear PTO mounts. I am also short, fat, old, out of shape. Just had a hip replaced 3 weeks ago and already back cleaning snow. Was out 2x today. Here is my 2 cents for what its worth.
- A good quality machine will last you a lifetime with minimal maintenance especially if stored indoors.
- Getting a blower at least as wide as your rear tire tracks is important. Otherwise when blowing the rear wheels are riding up / fighting through the unblown snow and causes off cantor and traction and compaction issues. Same with a front blower.
- A rear pto mount leaves your front loader on which is great for cleaning up edges, getting into corners, cleaning up alongside gates, steps, back blading around buildings, making piles when space is short, when only small amount of snow on ground and a fast push is all that is needed, if you have metal roofs in your area and snow clears off the roofs or if the grader leaves wind rows on your front drives and they set up (or worse grader plows compacted road coverings leaves compacted / frozen blocks of road ice) then having your front bucket is really important as a blower on a machine won't cut it..
- Ground speed in reverse when blowing is very slow and generally blowing in fairly straight lines so a set of mirrors really minimizes how much I need to look back. I also blow in very rural area so I know if my dogs are in the house there is little/no danger of someone/some thing walking in my way. (I use a glove mounted mirror I bought at a snowmobile dealership which I find very usefull)
- I like open chain drives as they are cheaper and never seem to break. And if a chain breaks fix is quick and easy versus having to repair a chinese gearbox which I see a lot of in the market. Chain maintenance is nothing more than every 15 hours or so pouring some gear lube from an old ketchup bottle onto the chain.
- I "felt" the 60" blower on my B2620 was on the larger size. Lots of PTO horse power just the tractor could have used more weight. Tires are not loaded. 66" on the L3301 does not have this feeling.
- For me the ideal situation is snow blower on back and a snow pusher bucket on the front.
Beaver Valley Supply Company - Worksaver Snow Pushers & Snow Blades
a lot depends where you live of course. In Quebec where 3 to 4 meters (12 feet) of snow is common in a season and having to navigate without the need of a front bucket but around parked cars and in public places where people may come and go then maybe I would change my mind on preference for rear pto.
so some ideas and points for you to considered based on your specifics!
cheers
/ Need advise. #9
My two cents worth is think about a pull type of blower. This way you are driving looking forward and you still have your loader when needed
/ Need advise. #10
My tractor is larger, but I invested in a pull blower and have my rear blade mounted on a SSQA adapter plate.
I get about 12 feet of snow a year. Nice to blow by driving forward and nice to have a blade in the front for back blading, light snow falls and pushing snow if needed.
2004 International School Bus (A64194)
2004 International...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
