MarkV
Super Member
- Joined
- Apr 7, 2000
- Messages
- 5,698
- Location
- Cedartown, Ga and N. Ga mountains
- Tractor
- 1998 Kubota B21, 2005 Kubota L39
Dave,
I tend to agree with what a couple others have said about not getting to crazy with the power recommendations. When you think about it the manufacture has to make his power recommendation on the high side to cover so many different types of uses. If I am buying a 6’ rotary mower to clear over grown power lines and need to cut 2” sapling at production speed I’d bet their recommended 30 PTO hp. would seem a little skimpy. On the other hand, in your case you are cutting established grass that you plan to cut once every 2 weeks during season and that just doesn’t take the same amount of power. If the grass gets away from you one month then cut at slower travel speed and take 4’ passes instead of 6’ passes.
The general rule of thumb for rotary cutters has been 5-6 PTO hp per foot of mower, depending on who you talk to. With my little tractor I would need a 2 ½ foot mower. /forums/images/graemlins/frown.gif The 4’ light duty mower I use has never caused my tractor to bog down and I have cut fields that the grass/weed was taller than the tractor canopy. It has also worked its way through areas of 1” – 11/2” sapling without complaint.
More power is always good! Will the 28 hp tractor run the 6’ mower even though it has 2 hp less than recommended, in my opinion, absolutely. If it makes you crazy not to follow the manufacture recommendations get a 5’ rotary mower and a 6’ finish mower.
Not knowing the tractor you are considering the other part of this equation is the ability to lift a 6’ rotary mower. That size rotary mower hangs way behind the tractor and weighs a lot. Make sure you have enough lift power and enough counter weight on the front to handle than much mower.
MarkV
MarkV
