Buying Advice Need advice on steering
/ Need advice on steering
I agree, very hard to be precise. I will attempt the twine circumference measure along with the diameter calculation. At the least they can be a check against each other.
/ Need advice on steering #12
I've posted the fix for this several times...
"I believe that everybody should adjust the sector shaft when they first get their tractor. It makes a amazing difference in how well the tractor steers at high speeds. Look on the side of the box. You will see an allen screw with a jam nut. Jack up the front of the tractor so the wheels are off the ground. Now loosen the jam nut and start turning in the screw. Keep turning it in until you start to feel resitance in the wheel when it's being turned. Back off the screw so the resistance is gone. Tighten the jam nut, but DON'T allow the allen screw to turn. If the screw turns when you tighten the nut you'll loose the adjustment. This screw adjusts the gear spacing and accounts for their wear. Over the years things will loosen up and the result is a tractor that tends to wander all over the road."
Also check your ball joints. It doesn't take much slop in the joint to have a ill handling tractor.
Thanks much! I knew I had seen you say that fairly recently and then I couldn't find it again.
/ Need advice on steering #14
Cord, that's the one I was talking about in my post but, I didn't know where her's was located on her 1500. Mine on the 3110 with ps is on the steering box itself . I thought that mabe the ps vs non ps & the different size tractors , the adjustment nuts may be in a different location .They may be all in the same place. Good luck roxy :)
/ Need advice on steering #15
Actually, the sector shaft nut is on every gear, worm drive or recirculating ball steering box out there. Doesn't matter if it has powersteering boost or not. Something to check if you drive a Dodge pickup and it wanders all over the road. Thanks for at least recognizing my prior posts. It's frustrating when you post the fix and nobody bothers to reply back.
Cord, your previous post in the other thread definitely had my attention about the steering. But, some of our threads do get long and change topics and that is why I couldn't come up with it again. I should have copied it or printed it off when I saw it. I tried doing a search and didn't find it. It is appreciated greatly that you came on here to tell it to me again:). Maybe I've been lucky but both my Dodge trucks drove nice and straight. Is there something peculiar to Dodge that I'm missing?
/ Need advice on steering #17
depending on year, yes... trac bar is another gotcha with the dodge truck... Trucks diesel or gass? Diesels seem to wear the f-end harder... See, here we go again, changing topics ! LOL
Both gas. First one was a 95 that I sold last fall. And I worked the snot out of that truck as a daily driver, tow vehicle, farm vehicle. The current one is 3 years old now (2003). On the 95, the big torsion bar had the ends wear out and when it would pop out of place, the truck went bucking down the highway. It was pretty awful, felt like the whole thing was just going to fly apart. Luckily my mechanic friend figured out right away what it was because it had happened to a Chevy 4wd he had had. The Dodge dealer did tell him (couldn't get the part aftermarket) that it happened to all of them and that they sold at least 7 a week. Sounds like that should have been a recall. As far as the steering on it, I had to replace the power steering pump at around 180,000 miles and no other problems. I did have a hose clamp break for the power steering on the 2003. It cost me less than $1 to fix.
We do change topics a lot and I'm guilty of it as well. There is tons of useful information in all our threads, but much of it is off topic. I enjoy our forum very much and I read every thread to learn everything I can about whatever topics. But, from now on, when I see something I need I should copy it or print it off so I don't lose it.
/ Need advice on steering #20
I have a diesel Dodge and that trac bar is a real b-otch. A Luk's link kit solved that problem. Adjusting the sector shaft and also helped quite a bit. But I'd hate to get things off topic... :D
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
Honda EB3500 Portable Gasoline Generator (A59317)
Honda EB3500...
iDrive TDS-2010H...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
20800 (A56859)
20800 (A56859)
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
