Need advice on a larger chainsaw for an older guy.
   / Need advice on a larger chainsaw for an older guy.
I guess you guys are right. Must be a dull chain.
   / Need advice on a larger chainsaw for an older guy. #163
I keep wanting to ask the OP if he thought about sharpening his chain but I hate to pile on. Oh wait, I just did.
I think like a lot of threads they tend to drift after a while. I think people are just sharing there sharpening ideas at this point.
   / Need advice on a larger chainsaw for an older guy. #164
Yep, this is my fault. I want to apologize for that. I jumped the rail in hopes of helping the OP cut faster and it derailed into a direction not needed at all by recommending a new fangled, not needed, piece of crap sharpener that any real chain sawin', chain sharpenin' logger would not keep in his pocket much less confess to using it.
   / Need advice on a larger chainsaw for an older guy. #165
Since we're off the rails already let me ask - are these Stihl sharpeners crap too?
I have a collection of chains that I usually use until they're blowing smoking sawdust (too late, I know) and every once in a while I take a few to town where the local stihl saw shop sharpens them for $5 each, but I wouldn't mind getting more mileage out of my chains and I've been thinking about getting a couple.
   / Need advice on a larger chainsaw for an older guy. #166
The OP is able to do stitches so I’m quite sure filing saw chains will be easily within his skill’s range.
   / Need advice on a larger chainsaw for an older guy. #167
So N80, have you decided to go for a bigger saw?
I certainly have gotten dividends from doing so, but keep the 50 and 60cc for doing different jobs with different bar lengths. I use 18/20 on the 490 and 24" on the 620.
I have a pole saw with 10" blade for overhead and cleanup of fallen branches.
I find all three cover what I need quite well. Time for me is an issue, that's where the larger saw also helps.
   / Need advice on a larger chainsaw for an older guy. #168
Yep, that's the crappy, plastic new-fangled sharpener that I love. Find a video and give yourself 5 minutes with it in your hands. It will sharpen the teeth and also set the cutter depth so you get a good shaving coming off of it. I keep a small vise on a bench and a marker to know where I started. When I see it getting a little dull, I will run this through about 4 passes/tooth on the next fill-up. It takes very little time. That keeps me from changing out the chain and making more adjustments to the bar. I guess others prefer doing them all as a project but I keep the same chain on until it's toast. just make sure you get the right one for your chain.
   / Need advice on a larger chainsaw for an older guy. #169
By doing that you’re missing a few huge things that will help the chain last longer one is removing the chain to clean bar rails and flip the bars so you’re rails wear evenly. I look at it differently then most of the guys here I’m falling for production so swapping a chain is faster then filing a chain.
   / Need advice on a larger chainsaw for an older guy. #170
Sharpening a chain is just one of those things you have to jump in and do.
2019 CATERPILLAR  XQ60 GENERATOR (A58216)
2019 CATERPILLAR...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
2021 New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
2021 New Holland...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
