Need advice on a larger chainsaw for an older guy.
   / Need advice on a larger chainsaw for an older guy. #301
Skip chains make sense on super long bars.
Could you explain why that is, please?
When cutting very large wood, there ends up being a LOT of chips along the length of that saw kerf. It can start to clog things up, interfering with the normal motion and cutting action of the chain. Full skip has half as many teeth (left cutter - space - right cutter - space - left cutter, etc), so less chips in the kerf and a better "cleaning action" to pull the chips out without clogging things up. It also takes less power to drive a full skip chain, since fewer cutters are engaged with the wood at any one time - so if you are maxing out the power of your saw, a skip chain might let you use a little longer bar than it would otherwise be able to handle.
There is also a "semi-skip" chain: (left cutter - right cutter - space - left cutter - right cutter - space) that is an effort to split the difference.
If you are not cutting large diameter logs where chips clogging up the cut are an issue a regular chain will cut faster IF your saw has the power to properly drive the chain. Also, skip chains are not recommended for cutting small branches, such as limbing. The large gaps make for rough cutting in small wood, and can make the chain feel rather "grabby".
The safety chain that often comes on smaller box store saws is a skip chain: but they fill the gaps with a "bumper link" to avoid the rough cutting and grabby feel of a regular skip chain.
   / Need advice on a larger chainsaw for an older guy. #302
Think of it as putting larger and larger tires on a tractor. Eventually, it won't be able to turn them efficiently.
Eventually, with a long enough chain, with enough teeth contacting wood, the engine won't be able to pull it efficiently.
So you have to increase the length of the bar to get through larger diameter trees, but the saw will only handle so much load. So remove every other tooth. The load goes down, while the cutting length maintains the same.
   / Need advice on a larger chainsaw for an older guy. #304
Not often do I have a full day of cutting up trees.
But after a storm & the fallen stuff is cut up by my little saw(s) I'm thankful for our CS-590, sometimes marketed as Timber Wolf.
The CS-590 is heavy but if used right, the weight works w/ the operator. It cuts so fast, I'm in & out before the pinch sets in.
Have never tried the ''skip chain''. However after reading some of the experiences here, I will try it.
Must ask, is the ''skip chain'' requiring a different bar ?
Don't care to endorse the CS-590, only because of the starting issue.
Only draw back is the motor starting cold & restarts. But most is forgiven during the long tank operations.
At times of refueling I never shut it down. Same for topping off the bar lube.
Not to get off topic, it would be good to not have to be plagued by these little faults. . . .any suggestions.
Much appreciate the interesting input from the collective
   / Need advice on a larger chainsaw for an older guy. #305
There is no need for a different bar to run skip chain. However, like any chain, you do need to be sure you are getting the appropriate pitch, gauge, and number of drive links. (If I'm not mistaken, .375" pitch, 50 gauge is the standard bar and chain that comes with the CS-590.) Personally, I see no reason to go to a full skip chain unless you are running a 24" bar (the longest bar recommended for a CS-590), and then only if you are running that bar to bury it in big wood. (Skip chain is a detriment if you are just using that longer bar to get more reach for cutting small limbs.)
Can you describe your starting sequence in detail, both for cold starts and for hot starts? You are not using the choke for hot starts, are you?
On some saws (Husqvarna and Jonsered, for example - I can't recall if Echo works this way or not) when doing a hot start, turn the stop switch on, then turn the choke on and then push it back off again (before attempting to start). Leaving the choke on when hot starting risks flooding the saw, However, that move of turning the choke on and off again sets the "fast idle" which can make restarting easier. The fast idle will remain engaged until you "blip" the throttle to disengage it. (Don't pull the throttle trigger after cycling the choke, but before starting the saw, since that will disengage the fast idle. Some people inadvertently disengage the choke if they use the boot stepping on the handle method of starting and hit the throttle in the process.)
I've only used a CS-590 a couple of times when using a friend's saw to help him take down some "problem" trees. I can try to help, but your description may prompt some comments from those who use this saw regularly.
   / Need advice on a larger chainsaw for an older guy. #306
Do not gas up a running saw. This will eventually lead to a quite large fireball.
from cold:
For starting on my CS-490 I put on choke, switch on, the give it a few pulls until it gives a false start.
pull trigger to put the choke back and it usually starts on the next pull.
Om my cs-620P - push in decompression valve, pull out choke, make sure power switch is up,pull twice on cord, never more, hit trigger so choke goes back in , pull cord 1 or 2 times to start.
If I tried to start the 620p like the 490, it would just flood. The larger saws can flood more easily since they grab more fuel on each pull of the cord.
   / Need advice on a larger chainsaw for an older guy. #307
I have to admit, I'm doing about everything wrong w/ this CS-590. Poor thing, maybe it just needs a better operator.
Even using the compression release on restarts.
It has been common for me to trigger pull when restarting, in the past.
All cold starts were under compression release pressed in.
Yes, after setting a spell the choke was used to restart while warm.
Did no know about the choke out & then in to set the high idle
Is it common to start by setting the chain brake ? I do not but have heard others suggest this for safety .
Have check the plug often & YES it was soaking wet. Just checked after yesterdays work out & it was text book color, running dry & not black.
That was one start up & three tanks while idling at refueling & bar lube.
Have read & reread you suggestions. Funny how the little saws are near operator (ME) proof. All of our saws are Echoes . . . .4 bought over the last 30 years, all still running.
Good suggestion on the chain swap.
Thanks again
   / Need advice on a larger chainsaw for an older guy. #308
Have notice this CS-590 has its own combination for a successful start & restart.
thanks
from cold:
   / Need advice on a larger chainsaw for an older guy. #309
Skip chains make sense on super long bars. Otherwise my experience has been that they cut slooowly.
Best guess, less drag/friction from cutting teeth allowing longer bars for tree diameter.
IrishLoader answered the question.
I bought a Husqvarna 572XP that had a muffler mod. It came from out west and had a long bar. I put on a shorter bar and had the (skip) chain shortened. The performance was unimpressive. I then put on a full chisel chain, and it made a huge difference. I never used the skip chain again.
   / Need advice on a larger chainsaw for an older guy. #310
That's just how my saws work (my history is mostly with Husqvarna and Jonsered). I did not mean to imply that all saws worked that way. Others may not be the same.
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2012 FORREST RIVER SANDPIPER (A58214)
2012 FORREST RIVER...
2013 Yamaha YDREX4 Golf Cart (A56859)
2013 Yamaha YDREX4...
2008 FORD F350 SUPERDUTY XL UTILITY TRUCK (A58214)
2008 FORD F350...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
