Ballast Need advice for wheel weights
/ Need advice for wheel weights #1
Roger2561
New Hampshire, USA
JD 4500
Hi all, I have JD 4500 4X4 with FEL. During the summer when the fields are growing I hire myself out to flailmow the fields for my customers. I have a field that causes me a major sphincter pucker when I mow it. The mower weighs nearly 800 pounds. I mow travelling up and down the hill - its probably a little more than a 25 degree incline. Fortunately, there is a nice flat spot on the top of the hill and bottom of the hill allowing me a safe place to turn around. I don't think the FEL provides enough counterweight, although the tires have never left the ground. I have been thinking that I'd to take my old dumbbell weight set and retro fit them to the front wheels (Approx. 400 pounds worth of weight. ). Do you think that is enough to offer me a less stressful ride and help keep the front tires on the ground where they belong? Thanks.
/ Need advice for wheel weights #2
Why don't you just through the weights in the loader bucket out front to give you more stability?and its easy enough to remove them and it increases your down force the farther foward they are.
Jim
/ Need advice for wheel weights #3
Hi Roger,
I have a few spots that raise the hair on the
back of my neck and arms when I mow. If the
weights work that's the way to go or try going up
hill backwards pushing your mower, put a round
bail on your front bale spike and if all else fails.
do what I did. Put all the difficult mowing fields in
graze for cattle. Mowing is next to nothing now.
Happy mowing.
Paul
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Iranch High-End Tricycle (A64119)
Iranch High-End...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
