Need a box blade
   / Need a box blade #1
blaux61
Ohio
MF20
I have a 1974 mf20 industrial with the Perkins diesel. Was wondering what size box blade you all would recommend for that size tractor. I will be using it primarily to spread top soil but will occasionally want to use the teeth to tear up the ground. Was wanting to run a 6' blade if I could.
   / Need a box blade #2
I think you will be fine with that 6 footer. I use a 6' with my Massey Ferguson 230 which has less power (38hp).
   / Need a box blade #3
Tractordata lists your machine at 77.5" wide, so you need a 7' to cover your tracks. Lists at 42 HP with Perkins, so should pull the 7 footer, and you have plenty of weight for traction.
   / Need a box blade
Thanks for the info. I think running a 7' blade would be optimal.
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
City of Lakeland (A51691)
City of Lakeland...
