Need a back-up camera
/ Need a back-up camera #1
BubbaJr
Platinum Member
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
With my neck, I can't turn around very far to see behind me. As I get older this is becoming more of a problem. I have a B2650 cab model and would like to mount the monitor from the ceiling, and mount the camera under the back window, or maybe above it. I would also like to have an infared camera for nighttime usage. Any suggestions?
Thanks, Joe
/ Need a back-up camera #3
/ Need a back-up camera #4
If I don’t stretch and use my neck it gets stiffs, and it becomes hard to turn my neck. I never thought that the solution might be to never have to turn my neck. A camera on the tractor would help for that situation, but what about for the rest of the day? Maybe I should get one to mount on my hat.
/ Need a back-up camera #5
Just get a plain backup camera I got mine for $100 where? don't remember! Next get yourself a nice bright backup light whole lot
cheaper than with night vision unless you got the coin and don't care
check this out on amazon:
Rohent N02 HD Metal Truck Backup Camera Rear View Camera 6 Powerful IR Lights Night Vision Price: $39.99​
willy
/ Need a back-up camera #6
I picked this up on Amazon. Comes with 2 cameras, both on rear - this is the 'low' view one
and the 'high' view one,
It has a slot for a memory card to record (I don't use). It also has provision to keep track of time and time stamp your videos (requires a wire be kept hot all the time). I don't use that either. About $100
I've read reviews until I'm blue in the face and can't find one that trips my trigger. The one that ctgoldwing has looks pretty good. Can you tell me what brand and model it is and if you've had any issues with it?
Joe
/ Need a back-up camera #8
Joe
Hello Joe
Here is the link: 9" monitor with 2 cameras
As you can see I put both cameras on the rear. There are a lot of features I don't use besides the ones I mentioned above. One which may interest you is the ability to view both cameras split screen.
After just having my 2nd cervical fusion I was more interested in just the rear views :) It comes with one 5m and one 15m cable - waaay to long. I ended up ordering 2 of these 3m cable which could still be shorter. I just looped the excess & zip tied it to the tractor.
So far no problems with the unit. If the sun is directly behind me, illuminating the monitor, it is hard to see. I haven't found that to be a deal breaker.
What may be for you, wasn't for me, is the monitor is NOT weatherproof. That said I plowed with my back blade is some pretty cold temps and the monitor was fine. It also got soaked once in a rain when I forgot to take it in :( I garage my tractor and do not operate it in the rain. As hard as I've tried it still chugging along.
That looks pretty close to what I need, but maybe with a little smaller monitor. Can you tell me what the remote controls?
Thanks, Joe
/ Need a back-up camera #10
In-expensive stuff these days works pretty darn good. I had to replace a monitor after a couple of years, but they're cheap enough that it's not a big deal: the plus is that the newer monitors now have a single plug connector which eliminates any need to rewire.
Lots of info in this thread:
A backup camera for $50!!!!!!!!!!!
/ Need a back-up camera #11
Thanks, Joe
Sorry Joe, just saw your question :(
I really don't know :) I probably threw it away or put it on one of the garage shelves (same as throwing it away :) )
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
PALLET OF SUMP PUMPS (A68842)
PALLET OF SUMP...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2014 KENWORTH T800 TRI-AXLE (A67714)
2014 KENWORTH T800...
