Nail in tire
/ Nail in tire #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
What should I do to fix? Remove and slime, plug, or have someone patch from the inside. ( This is the left rear and they are not filled) Any suggestions.
/ Nail in tire #2
Had the same problem yesterday, could not plug due to tube so removed wheel and had tire shop repair tube and a patch inside the tire. This wheel off a Kubota L3600 and 13.5X24 rim and the charge was 20 bucks worth it to me.
What did you end up doing? ken
/ Nail in tire #3
Crown,
For nails/screws I would plug if no tube is involved. Also as Hazmat experienced recently make sure it's leaking before plugging!!
Carl
/ Nail in tire #4
Crown,
Learn from my mistake <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=parts&Number=196604&page=0&view=collapsed&sb=5&o=&fpart=> Flat tire 101 </A>
Also instructions <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=parts&Number=195377&page=0&view=collapsed&sb=5&o=&fpart=> How to plug a tire </A>
I got the T handle kit from NAPA.
/ Nail in tire #5
If tubeless plug AND THEN GET THE SLIME!. After plugging my third hole I got the slime from gemplers (pink stuff, not green and a lot cheaper than the little pints you by at most stores. Comes in gallon jugs or 5 gal pails). Cost me about $90 and I had enough to do all 4 tractor tires, all 4 garden tractor tires and all my wheel barrows. Haven't had so much as a slow leak since and it's been over a year. Well worth the cost.
/ Nail in tire #6
Guys,
These nails are a bummer to say the least.
I have one area that a previous owner must have used for a trash pile since I have had two flat tractor tires and several flat truck tires from this one area.
I finally got one of those magnets on a stick and went around looking for nails and metal. The attached is what I found...a couple of pounds of nails, old bolts, and sharp metal pieces!
Fred
/ Nail in tire
I had to go out of town this week-end but I will go to NAPA and purchase the kit and give it a go on Saturday.
Thanks to all for the advice.
John Deere Z925M (A64912)
John Deere Z925M...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
1990 Wabash Flatbed Trailer (A64912)
1990 Wabash...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
