Who plugs tires?
/ Who plugs tires? #121
/ Who plugs tires? #125
It's the caulking "tool" in the post. Those can be scary.
Un-reinforced adhesive or caulk would indeed be scary. But if it were reinforced with glass or carbon fiber, and one could find a way to do that which didn’t develop small leaks over time, it’d likely be stronger and better than the surrounding tire.
/ Who plugs tires? #126
DB's question was why his post needed approval. My reply was meant to point out the word "g u n" being "the issue" using the term "tool" to replace that...
/ Who plugs tires? #127
So, I did order that silicon coated screw type plugs. I did use one, and installation is Easy. The issue, was, it still lost about 10 psi per 24 hours. So, yeah, I left it in for about 3 weeks; but just yesterday i took it to tire shop, and had them put a patch-plug in.
I can't say if the continued leak is a fault of the screw plug, or if maybe it was a bad application, or there was a small secondary hole next to the main hole? So, im not gonna throw the 20ish remaining plugs out, but I fall short of being able to recommend them either.
/ Who plugs tires? #130
Out of all the hundreds of tires that I have plugged in my life I have only had one fail and it was against my better judgement to plug that particular tire right on the edge of the sidewall, it failed the next morning I assume due to the tire sidewall flexing, other than that I have never had not so much as 1 issue plugging tires.
/ Who plugs tires? #131
I don't blame the companies for CYA.
I blame the lawyers/people who sue them. Sometimes, stuff happens. A patch might fail.
The rear location for new tires chapped my behind. The consequences of fishtail may be worse, but the advantages of better tread on front (FWD or AWD) are constant.
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
UNUSED FUTURE EXCAVATOR THUMB (A60432)
UNUSED FUTURE...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
