My way
/ My way #1
n8586m
Stanwood Mi
Kubota B2620 w/FEL
I though I would share how I handled the trailer situation. The tractor is a Kubota B2620, with filled tires it weights about 2000 lbs, MMM is about 300 lbs and loader is another 600 lbs, total is 2900. The trailer is a 7k by 16' tandem that weights 1300 lbs. The sides I built are 5/4 x 6 treated deck boards, about another 300 lbs so the trailer is 1600. Total load is then 4500. The truck is rated at 5000 for the trailer load. After a few hundred miles it seems lake a fine match. Notice the aluminum ramps. Very light but rated for 5000 lbs. They are Dambach's costing about $200 delivered. The rear support is obvious and if trailer settles on it, just drive ahead 3'. There a lot of ways to rig your trailer but this works for me.:)
/ My way #4
For trailer support I use jack stands that have the handle you lift up to release. Works slick.
jb
/ My way #5
I had a set of ramps once upon a time like those you have only they were in steel. The very first time I used them was to load a Chrysler shadow (very small car). As soon as the car front tires were midpoint on the ramps they fell to the ground in a crumpled mess. I think the ratings are a little miss leading. I would be careful and maybe block the center of them. They are really designed for lawnmowers and ATV's.
/ My way
wkpoor
Nope, these are not for atv's. Check out Dambach's web site. They have ramps good for 10,000 lbs.
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
